Door switch problems. - Mustang Evolution
Old 05-31-2007, 04:52 PM   #1
matthews.stang's Avatar
Exclamation Door switch problems.
Okay, so a new problem snuck up on me today. Sometimes when I open the door none of the switches will work on the passenger side and the dome light will flicker on an off as the door moves.
I am thinking it is a ground problem in the door. Any ideas on where to start?
(I had a Ford Tempo that did the exact same thing also. )
And it has now gotten worse.
On the driver side, the door lock switch, both windows sitches, and the power mirror switch no longer work.
I took the swtiches out and test for power on the wires. I was getting power on all four. All the fuses checked out. Is it even possible for all of the switches to go out at once?
matthews.stang is offline   Reply With Quote
Old 05-31-2007, 05:33 PM   #2
bullitt482's Avatar
Re: Door switch problems.
I have the same problem with my interior lights, they no longer work...
01 Bullitt
Old 06-04-2007, 08:39 PM   #3
Yea well, I replaced the One Touch Module today since it was making an arcing noise, same problem. The door lock switch only works when the key is not in the ignition. Once the key is turned, nothing.
So it is going to the dealer. I give up.
Keyless entry problems /w drivers door itrorev 1996-2004 Mustang GT 4 10-14-2008 02:12 PM
Door Panel Problems Justin 1979-1995 Mustang GT 8 10-11-2006 01:51 PM
switch help! jimmy_beaner The Bar 10 11-22-2004 11:51 AM
door lock problems WhiteStang99 Pre-2005 V6 Mustang 9 04-06-2004 04:36 PM
Tranny Switch starboarder2004 Pre-2005 V6 Mustang 10 01-28-2004 11:27 AM
05:45 PM
