P301 Missfire Cyl. 1 - Mustang Evolution
Old 06-02-2007, 11:21 AM   #1
BruThru2002's Avatar
Send a message via AIM to BruThru2002
Ok, so this is what I got. A few days ago I got this missfire code off my car. So Ive replaced the Coil pack, spark plugs, spark plug wires, O2 sensers, and the fuel injecter, and the code is still poping right back up. Any ideas from anyone? Maybe fuel filter?
Also, When Im driving the car, and just a small amout of load needs to be put on the throttle (maybe between 1,200 and 1,600 rpms), the car starts to shake. Its definitly not the tires unblalanced because if i get on the gas a little harder (2,000+ rpms) or there is no load on the throttle, the car is running fine, and not shaking. Car doesnt have any idleing problems either, sits just fine.
Anyone got any ideas what it could be and why it would cause a code for missfire in cylinder one?
2000 Mustang....
~ Performance Red, New Mach 1 (Mag 500) rims, Dual Flowmaster Exhaust, Black Letters & Rocker stripes, Sony - Rockford Fosgate system
-Billy
BruThru2002 is offline   Reply With Quote
Old 06-05-2007, 06:14 PM   #2
Re: P301 Missfire Cyl. 1
grabbed a tool today to check the compression in cylinder 1 to see if there is a loss of compression. Its about the only other thing I can think to check. Anyone know what range I should expect to see for a good cylinder and for a bad one? Thanks.
2000 Mustang....
-Billy
Old 06-05-2007, 06:16 PM   #3
bbunt302's Avatar
The best way to tell is to not measure a single cylinder, but rather measure them all and make sure they are within a pretty tight range. Different motors may have different compressions. The important thing is to see if you have a cylinder that is lower than the others.
Scary stuff.
Old 06-06-2007, 07:40 AM   #4
MonteCitan's Avatar
fuel filter would be more of a p0300 or more than just cylinder 1.. -- when you did the plugs, was there any oil/fouling of the cylinder 1 plug?
Check the crank position sensor lately?
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
1993 4 Cyl Swap KawaFord 1979-1995 Mustang GT 24 03-23-2009 12:02 PM
I need help deciding what dual exaust to put on my 6 cyl. Prest_2890 Pre-2005 V6 Mustang 43 09-02-2008 01:38 AM
Missfire Cylinder 1 BruThru2002 Pre-2005 V6 Mustang 12 05-15-2007 03:36 PM
88 notchback.. 4 cyl.. MonteCitan Mustangs for Sale and Wanted 4 05-19-2006 01:13 PM
4 Cyl to a V-8 Firaboy 1979-1995 Mustang GT 9 07-16-2004 09:07 AM
12:24 PM
