Steering wheel vibrates back and forth - Mustang Evolution
Old 06-09-2007, 06:34 PM   #1
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
yea, like the title says. since i got the stang back 2 weeks ago, i've been having some vibration transmitted though the steering wheel. it started off fairly mild, but it's getting slowly worse. it starts to kick in around 40mph, and gets more noticable from there... i'm thinking it's just the alignment being out of wack from the car sitting for the better part or 2 years, but i figured i'd get opinions anyway
I will probably be putting a MM coilover kit on it in the next month or so, so if it is an alignment issue, that'll solve it. but if it's not the alignment, what might it be?
dark is offline   Reply With Quote
Old 06-10-2007, 02:44 PM   #2
bullitt482's Avatar
Re: Steering wheel vibrates back and forth
Get your wheels balanced first. Especially since the vibration is relative to speed.
01 Bullitt
Old 06-10-2007, 03:30 PM   #3
dark's Avatar
alright
I don't own a mustang at the moment
Old 06-10-2007, 04:59 PM   #4
Most place will check alignment and balance for free...only if it needs to be adjusted will they start charging.
Old 06-10-2007, 10:12 PM   #5
I liek gramer
WhiteStang99's Avatar
Make sure the lugs are tight...?
Old 12-19-2007, 07:03 PM   #6
I borrow this thread for a moment as I am experiencing major problems with steering weel vibrating when getting up to speed. It usually starts at 50 mph or so, but not all the time. Sometimes it is worse than others, and sometimes it does not vibrate at all.
I have aligned the weels, balanced the weels, changed tires, and then did alignment and balancing again. Problem remains. I have even suspected the car being in an accident before I bought it because the way it is handling.
My car is an 01 Mustang Convertible V6. Any ideas are more than welcome.
PS. I have no previous experience from Mustangs so my knowledge is limited.
Thanks for any help out there!
/Stonemountain
stonemountain is offline   Reply With Quote
Old 12-19-2007, 07:20 PM   #7
meteorachick's Avatar
i just had an accident, had 2 front wheels replaced and it did the same thing, the steering needed adjusting, and i needed a major alignment
that seemed to fix it for me :dunno:
Modified 2004 V6
Old 12-19-2007, 08:01 PM   #8
if your rims are not hub centric then you can have issues even with a properly balance tire with shacking. If it isnt the tires, it could be the rotors (not usual but it does rotate) or the steering shaft~ or the rack etc something along the pipe line.
Old 12-19-2007, 09:52 PM   #9
MonteCitan's Avatar
/Stonemountain
Check your u-joints on the halfshaft, or have someone check them.. the randomness of your vibration is very typical.. it can be fine sometimes, then a certain road vibration or load will set the vibration off and it'll get worse for a bit, could also be the rear
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 12-20-2007, 07:17 PM   #10
rocknbronco's Avatar
Get an balance/rotation and an alinement also if you get new tires soon get someone whom will give you a lifetime alinement, I got it on my F250 and love it......
Check your local Firestone.
rocknbronco is offline   Reply With Quote
Aftermarket steering wheel jch_1120 Pre-2005 V6 Mustang 7 04-13-2010 08:34 AM
steering wheel please help?!?! rello Pre-2005 V6 Mustang 14 08-01-2009 06:07 PM
Wiring Under Steering Wheel Justin 1979-1995 Mustang GT 5 11-28-2006 09:03 PM
What steering wheel is this? HotRod.riguez Mustang Audio & Video 5 11-28-2006 09:19 AM
Steering Wheel natebest2000 Mustang Audio & Video 7 02-16-2005 12:22 PM
09:31 AM
