Limited Slip Differentials - Mustang Evolution
Old 06-12-2007, 12:43 PM   #1
I'm trying to find a good limited slip differential for a 7.5" rear end. I'm told Auburn and Eaton are very good quality. I just cant seem to find any that arent for the 8.8" rear end. The regular trac-lok just isnt going to be strong enough for the application I am doing. If it helps, this will be my setup:
4.2 Stroker, NA
3.73 rear gears
Stage 2+ clutch/Aluminum flywheel
Thanks.
SuperItalian is offline   Reply With Quote
Old 06-12-2007, 12:44 PM   #2
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Re: Limited Slip Differentials
Detroit Tru Trac, that is all. :approve:
DarkShadow is offline   Reply With Quote
Old 06-12-2007, 01:24 PM   #3
The OEM tlok unit will be fine unless you plan to rag it out on the drag strip. By OEM I just mean the OEM tlok they make for the 7.5 inch rear.
If you plan to drag race it or run sticky tires then it might be wise to upgrade to a better unit as mentioned above so you dont have to tear down or replace the rear end as it can be expensive.
Old 06-12-2007, 01:55 PM   #4
It's just going to be a daily driver. It will never see the track at all. If thats the case, then just a regular unit will be alright? Like maybe get the Ford Racing T-Lok Differential?
Old 06-12-2007, 02:42 PM   #5
rydog's Avatar
Send a message via MSN to rydog
I have ragged the **** out of factory t-locks and never had a problem with them
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 06-12-2007, 02:54 PM   #6
Well, because of what my setup is going to be (4.2L Stroker, with an eventual single turbo setup) I am hearing that the factory unit wont be enough. I'm looking into the Detroit Tru Trac from drivetrainspecialists.com. That should be a solid enough unit without having to swap the whole damn rear end out hehe.
Old 06-12-2007, 03:48 PM   #7
bullitt482's Avatar
Running a Auburn Pro diff here and like it. If I changed I would go with an Eaton Posi.
01 Bullitt
Limited Slip Rainman64 Classic Mustangs 2 10-17-2009 12:24 AM
limited slip manic5_2001 2005-2010 Mustang GT 10 04-11-2008 12:01 AM
Posi, T-Lock, Limited slip? fasternu_674 Pre-2005 V6 Mustang 2 10-16-2007 11:23 PM
detroit locker vs. limited slip oaktonarcher Pre-2005 V6 Mustang 15 07-10-2004 01:27 PM
08:55 PM
