Take off exhaust - Mustang Evolution
Old 06-12-2007, 05:27 PM   #1
Take off exhaust
Hi guys do you think taking an exhaust off a GT and putting it on a v6 is a good idea.
Stang02021 is offline   Reply With Quote
Old 06-12-2007, 05:32 PM   #2
Y2E0L0L5OGWT's Avatar
Re: Take off exhaust
it depends on why you are wanting to do it...is it for sound (which I don't think you will notice much different from your stock v6 exhaust), looks, or performance (or lack there of)? also, how much of the exhaust are you talking about? just catback or what?
Old 06-12-2007, 05:34 PM   #3
probaly for some sound and performance. if gt isnt the answer for exhasut than what do you think fro under 400
Old 06-12-2007, 05:48 PM   #4
here are a few companies with some dual conversions for v6's, but these aren't "true dual" setups, they just have a y-pipe that splits into two at the rear...
JBA Evol™ Exhaust Systems 05-07 Ford Mustang 4.0L V6
MagnaFlow Performance Exhaust - For American Muscle Cars
those are both over your $400 range though...plus if you want to go with true duals it will get more expensive than that...from a cost standpoint, you could go with the GT style setup for fairly cheap...you would need the stock catback from a GT and then youd also need to find an x, h, or y pipe to connect them somehow...
Old 06-12-2007, 07:55 PM   #5
I liek gramer
WhiteStang99's Avatar
I have takeoffs on mine and I really like them.
Best way to do it is ask around at local exhaust shops, see if they'll call you when they cut stock exhaust off of a GT. Free exhaust.
They do sound slightly better, but it's not amazing, and I *think* i noticed a little more torque.
Old 06-18-2007, 03:35 AM   #6
rmays06's Avatar
Take offs are the cheapest and easiest way to go. You'll get decent preformance and its fast to do. The sound is MUCH MUCH Better than stock V6 exhaust...GOOD luck
Car: 2006 Tungsten Grey, Mustang Side Louvers, White Brake Calipers, Flowmast Axle Back, TI CAI XCAL 2, Dyno tune by Alt Auto, many look good mods interior and exterior.
www.tungstengreyregistry.com member #001
My Ride
rmays06 is offline   Reply With Quote
Old 06-19-2007, 02:27 PM   #7
rocknbronco's Avatar
I wouldnt try a GT exhaust just get one built for a V6.
rocknbronco is offline   Reply With Quote
Old 06-20-2007, 02:37 AM   #8
rmays06's Avatar
Why? Its the cheapest and opens the car up alot more. yes there is tons of after market kits out there but most really like the GT take off.
My Ride
Old 06-20-2007, 03:47 PM   #9
Well a V6 doesnt have the same exhaust flow as a V8.
Old 06-21-2007, 04:40 AM   #10
rmays06's Avatar
:hammer:
Is there anyone in there?
It is a direct bolt on and cost about $25.....what don't you understand about a GT take off? :yank:
I just read some of your other posts, I see where your coming from now, you just don't get it.....
You can and many do put GT take off mufflers on the S197 platform. They bolt directly on the Ford mounts....They breat alot better with the GT take off and sound much better. They have the same size pipes and well it just makes sense. They do flow the same!
GOOD LUCK and I hope you now know more about the S197!
My Ride
Old 06-22-2007, 07:07 PM   #11
Originally Posted by rmays06 View Post
:hammer:
If you want the GT sound you should have gotten a GT
Old 06-23-2007, 01:58 AM   #12
rmays06's Avatar
Well seeing as you a mechanic in TN I'll break it down for you!
He asked about putting a GT exhasut to improve sound.....not to make his motor bigger! He didn't ask about buying a GT or having a V8. NOPE he asked about improving sound quality.
The GT take off is a good option that alot of people use. Since you don't own a V6 or GT in the S197 you don't know do you? Does this car flow like a GT probably not but a 5.0 doesn't flow like a 4.6 either does it?
I bet the designers and engineers at Flowmaster, Borla, Bassani or JBA didn't sit around and say you know what the 4.6 and 4.0 don't have the same exhaust flow so lets redesign a new tube/chamer/canister for the 4.0......HAHA no way they put bracket on mufflers and sold one for the V6 4.0. They didn't do anything different, neither did Ford. But seeing as you wrench for a living you should know that.
Check it out smart guy, stay out of the V6 S197 tech board if you aint got anything good to say or if you just don't know. The last thing I wanna read in a post by a guy who don't own a S197 is you should have done this.....it don't fly.....
My Ride
Old 06-23-2007, 09:10 AM   #13
No your not getting what I am saying get something built with the V6 in mind to scavenge to most horse power from your ride from the headers back, yeah I am a part time mechanic now I used to co own a performance shop it pissed me off folks trying to cut corners to build horse power or get a "look". I'm a tightwad myself and will sit and wait for the right part at the right time, the reason my build take longer, if its my own build up that is, as most customers dont want to wait or save a few. There is now way a 4.0 V6 and a 4.6 V8 have the same exhaust flow, yes they may share the same muffler or pipe size but those or two seperate engines with seperate numbers on the dyno. Build something with what you have in mind yeah I dont own a S197, thats true, but I will offer my advice and politely with out taking low blows. I'm very particular when I work on a car when I do it I do it right the first time I have had or have seen to many cheap build go south quickly and cost more....Doing the job right to get the most power is something nowbody can argue with in the right mind set.
Old 06-23-2007, 10:12 PM   #14
rmays06's Avatar
Very impressive post! Thank for the info. Tons of people have done the GT take off to open the V6 up and sound better. Its a way to do it cheap.
Again, I understand you and basically agree
My Ride
Old 06-26-2007, 08:30 AM   #15
Ponyone's Avatar
Did it and it's MUCH BETTER than the single JBA I had previously...
ID:	17502   Click image for larger version
Ponyone is offline   Reply With Quote
exhaust
01:01 AM
