96 v6 Cooling problems. - Mustang Evolution
Old 06-14-2007, 11:37 PM   #1
Send a message via AIM to V6Polish
Here's the deal.
I have a 1996 v6 3.8 and when I first bought the car the temp gauge was always at the factory 195. Lately is has been rising to about 3/4 but not redlining. I do not feel comfortable with the temps it is reaching.
I have replaced the thermostat and the 2 gaskets(though there was no leakage) and have checked the fan which is working.
Basically I need help figuring out what it is that may be causing my temp to rise to un comfortable levels.
V6Polish is offline   Reply With Quote
Old 06-15-2007, 07:05 AM   #2
Re: 96 v6 Cooling problems.
Are you using the stock gauge or an aftermarket to determine the temp? The factory gauge is not very good and my first step would be to test it with another more accurate gauge like from autometer.
If you are using a good temp gauge then check your coolant and look for signs of a head gasket leak.
Old 06-15-2007, 09:12 AM   #3
Yes, My Gauges are stock. And I flushed the radiator and refilled it with 50/50. I suppose I will check for head gasket leaks and get back to you if problems persist.
Thanks
Old 06-15-2007, 11:47 AM   #4
Check the fluid level you may have air in your system if you did the drain/fill recently and especially if just after this the issue started to happen.
Old 06-15-2007, 04:21 PM   #5
I did not see any apparent leaks around the head. just a minor leak on the oil pan gasket.
I checked the coolant levels and they are fine as well.
I checked under hood and dash fuses, they do not appear to be burned popped or melted.
I am out of ideas. I checked the water pump by squeezing the upper radiator hose and i felt the fluids rush. So it doesnt make sense to be the water pump.
The upper hose is hot so i can tell that the fluid is circulating.
Old 06-15-2007, 07:17 PM   #6
rocknbronco's Avatar
Get a compression guage and do a leak down test on it.
rocknbronco is offline   Reply With Quote
Old 06-15-2007, 08:48 PM   #7
Kiljosh's Avatar
Flush your whole motor a few times with a specialized cleaner.
Scaling buildup is all I could think of at this point(considering what you have checked)
Old 06-16-2007, 10:06 AM   #8
Get a real gauge and test it first it could just be the stock POS gauge... you never know.
Old 06-16-2007, 03:15 PM   #9
Well, I usually run with the heater on, if I dont the temp meter will stay around 3/4. When the heater is on it will be somewhat normal but still fluctuate in lower temperatures.
If it wouldnt be too much trouble, could someone send a link to a good gauge?
Old 06-17-2007, 10:00 AM   #10
Autometer has a good gauge but i would have for you to spend a ton on something you will only use couple of times.
Old 06-17-2007, 12:04 PM   #11
X2
Old 06-17-2007, 07:36 PM   #12
matthews.stang's Avatar
105-2355 Autogage Water Temperature Gauge 100-280 F
1-1/2" electrical
Black face/white accents
More Details
$32.99
Auto Meter Autogage Gauges - JEGS
matthews.stang is offline   Reply With Quote
Old 06-19-2007, 04:30 PM   #13
Hey,
I am becoming very frustrated. I replaced my thermostat and my radiator and I am still having some issues with my cooling.
Any input?
Old 06-19-2007, 05:23 PM   #14
I spoke with a mechanic. He says that most likely I need my heads machined because they are warped if infact the temp gauge is correct.
I have yet to try a new gauge, but definitely will do that soon.
I despise me luck with vehicles.
Old 06-30-2007, 08:36 PM   #15
Would the heads being warped make sense in this case?
Old 07-01-2007, 02:05 PM   #16
Kiljosh's Avatar
I would think with warped heads you would have coolant in your oil or else spewing smoke out of your exhaust that smells semi sweet.
Old 07-01-2007, 02:12 PM   #17
Or you have a blown headgasket.
Old 07-02-2007, 09:29 AM   #18
Hmm, there is no smoke at all, if i saw smoke i would have known head gasket or rings. I am very annoyed since i just got this car to get away from the honda . I had tons of problems with that car.
Anyways, how can i find out if there is coolant leaking into my oil?
Old 07-06-2007, 06:50 PM   #19
Well, I drained my coolant again, and replaced with straight up water, it is running alot cooler and there is little if any fluctuation showing on the gauge.
I guess I had a bad mixture of coolant. And since the engine got so hot, im sure i have other problems now...
Need help with cooling system Dman Pre-2005 V6 Mustang 5 06-16-2007 10:35 PM
Burping the cooling system? I_luv_HP&trq General Car Discussion 2 09-06-2006 09:55 PM
cooling 9899musl 1996-2004 Mustang GT 0 03-14-2006 05:24 PM
Cooling issues lightning 1996-2004 Mustang GT 5 10-12-2005 10:12 AM
My Cooling System 04MonteSS The Bar 12 07-30-2005 03:50 PM
07:29 AM
