Mechanical question - Mustang Evolution
Old 07-02-2007, 09:00 AM   #1
Mechanical question
I've been having some issues when first taking off to drive my car, seems to be only a first gear thing. When I take off, I have to control the clutch extra carefully or else the car will shake like its about to stall. The clutch cable is a tab loose and needs to be tightened, but could there be a bigger problem at hand? I am by no means inexperienced with the standard shifting cars, since that's pretty much all I have ever driven, so I know its not me, plus I've had this car for about 2.5 years now, so I know that something isn't right.
HotRod.riguez is offline   Reply With Quote
Old 07-02-2007, 11:11 AM   #2
Re: Mechanical question
Try to take up the slack in the clutch cable via the stock quadrent (force it to take it up if it wont do it on its own by holding the quadrent as you ease the clutch petal from the floor back out to make the pawl gear click up and take up slack)
Can a mechanical water temp guege be installed. rob4292 1996-2004 Mustang GT 3 05-17-2007 02:16 PM
Mechanical Problem megax29 Pre-2005 V6 Mustang 15 07-27-2006 06:13 PM
question for all sublimegt The Bar 8 08-02-2005 11:13 PM
mechanical or electrical gauges? tedness Pre-2005 V6 Mustang 1 03-26-2005 12:44 PM
06:25 AM
