Overdrive? - Mustang Evolution
Old 10-18-2010, 11:05 PM   #1
v0nz's Avatar
Overdrive?
Can someone explain what overdrive does and how and when to use it? Also, would it be better for racing?
Proud 2004 v6 3.8L Pony Owner.
v0nz is offline   Reply With Quote
Old 10-18-2010, 11:22 PM   #2
Re: Overdrive?
It prevents your car from going into Overdrive when you turn it off. Its basically like not going into 5th gear in a 5 speed and staying in 4th the whole time.
Its pointless to mess with when it comes to racing your automatic.
Old 10-18-2010, 11:29 PM   #3
04DSGM1's Avatar
Re: Overdrive?
You want to run overdrive mainly for gas milage. Overdrive really saves gas on long trip on the highway.
2004 Dark Shadow Gray Metallic Mach 1
K&N Air Intake
04DSGM1 is offline   Reply With Quote
Old 10-19-2010, 06:45 AM   #4
bryanbrock's Avatar
Re: Overdrive?
hahahaha this has always been a fun one! ok if you look in your owners manual it will actually give you a tow weight rating and tell you to turn the over drive off if you equip your mustang with a tow package and plan to haul something. you can see video's of theas goofy dudes pulling youhauls and johnboats all day long on youtube. i have seen it myself a time or two and think its retarded lol
bryanbrock is offline   Reply With Quote
Old 10-19-2010, 06:51 AM   #5
bryanbrock's Avatar
Re: Overdrive?
......watch this one, camero with a tow package towing a ford focus lol .....I bet his over drive is off
Old 10-19-2010, 07:08 AM   #6
Re: Overdrive?
its the same as 4th gear, its just another gear. The reason its called overdrive is because the gear is smaller than 1:1 ratio (rpm wise). It makes no difference to drive in regular or without it, its just another gear.
Old 10-20-2010, 10:31 AM   #7
Wolfsbain76's Avatar
Re: Overdrive?
I've heard and I practice turning the O/D off when in heavy traffic or using side roads that will not allow me to go over 40mph. It's great because instead of your gears changing too quickly, it will stay in 4th longer, hence, you can hit the gas on and off in slow traffic and stay in that gear longer. Just don't do what I do, once traffic picks up you gun it and forget to put it back on!!
Wolfsbain76 is offline   Reply With Quote
Old 10-20-2010, 07:22 PM   #8
tvsr's Avatar
Region: Nevada
Re: Overdrive?
I just always leave mine on it always goes to overdrive when i turn it on
tvsr is offline   Reply With Quote
Old 10-24-2010, 04:08 PM   #9
Re: Overdrive?
It is best to leave it on...it allows the transmission to engage that final overdrive gear (4th) where the engine is running smoother and more efficiently.
I believe the overdrive gear ratio is less than 1:1. That means ~ 3/4" turn of the crank is a full turn of the output shaft...the driveshaft is turning faster than the engine = better fuel efficiency and less wear on the engine.
Generally if you are traveling on a steep downhill, towing a trailer, or crusing around in the city 40<mph, than o/d can be turned off...since you don't want the engine to shift into that 4th gear. You'll want it to stay in the lower gears longer rather than upshifting. When driving, I've noticed that the o/d will engage ~40 mph. So keep that in mind.
As far as racing...the only thing it will do is make the car louder...so if you're one of those people (usually guys with hondas and fart cannons) who think the louder the car is the faster, then you'll be happy
For example...with o/d on, with no indicator light in the message center, while going 60, you'll be running ~1800rpms.
With it off, with the little green "o/d" light on, you'll be around 2300 rpms...with exhaust the car will be louder, but you're are putting more strain on the engine and your mpgs will drop noticeably.
So while in town with traffic/lights going less than 40, it won't hurt to have it off.
While on the highway, leave it on.
If you want to increase the performance of your transmissoin...get a tuner with custom tunes that will increase the firmness and precison of shifts. It is like a difference between night and day on these autos...definitely something to look into if you're wanting to increase performance with an auto.
Old 12-07-2010, 07:46 PM   #10
prephockeyplaya's Avatar
Region: Rhode Island
Re: Overdrive?
I'm Confused, When the light is on does that mean that the overdrive is off or on?? and when i ride hard like accelarating fast and braking hard, like the crazy driver i am, is it better to have it on or off. What about when i want to take my car over 100 MPH? better to have it off or on?? this would make things so much mor clear!
prephockeyplaya is offline   Reply With Quote
Old 12-07-2010, 07:52 PM   #11
Re: Overdrive?
When the light is on the "od" is off. When you are driving crazy then it would feel better to have it off. If you plan on driving that fast and want to save gas a little bit then have the "od" on.
Straublittleman is offline   Reply With Quote
Old 12-07-2010, 07:54 PM   #12
Re: Overdrive?
If i don't really care about gas milage would it then be better to have it off so that i can go into that 5th gear? or does the over drive being off prevent it from going into the 5th gear?
Old 12-07-2010, 08:07 PM   #13
Re: Overdrive?
With od off it will prevent it to go into high gear but you will still be able to top out your car over 100 mph. You'll still be driving fast but at a much higher rpm.
Old 12-07-2010, 08:11 PM   #14
Re: Overdrive?
Ok sounds good. Thanks so much for the help. I've been a member less than an hour and have read many threads and you've helped a lot of people out so i thank you for the help with me.
Old 12-07-2010, 08:16 PM   #15
Re: Overdrive?
No problem just glad I can help, and there's allot of people on here that have a lot of knowledge.
Old 12-08-2010, 07:13 AM   #16
Re: Overdrive?
you find out so much by reading and searching threads we all had to start out in the learning process
Old 12-08-2010, 07:20 AM   #17
sick04mustang's Avatar
When tha light is on its off.breaking don't really matter 100+ leave it on unless u want to replace tha motor as this tends to blow them up. good luck
04GT(BRANDI) VORTECH S/C,PATRIOT STAGE2 HEADS,ANDERSON POWERPIPE,SUPERCHIP,36IB INJECTORS,4.10, C&L INTAKE,ACCUFAB THROTTLEBODY, 1/2INCH INTAKE SPACER,EIBACH PRO SPRINGS,H.O.FIBERTRENDS 4INCH HOOD
sick04mustang is offline   Reply With Quote
Old 12-08-2010, 11:23 AM   #18
A.K.A. Baby-D!
Re: Overdrive?
speaking of overdrive.... i can no longer turn my OD off in my 04 V6.. like the button does nothing. any ideas?
Current:
1989 GT--the project
Previous:
2004 V6--my first pony
1988 GT--July 2010 MOTM
Old 12-08-2010, 11:32 AM   #19
Re: Overdrive?
could be a wire bad, are you sure its not just the light thats bad? If you are in overdrive and you push the button does the car downshift?
another way to test is get in the car turn it on, push the OD button then pull it back in 3 and go driving get to speed and make sure its fully shifted out into 3rd then push it into D if it shifts again thats over drive
Old 12-08-2010, 11:42 AM   #20
A.K.A. Baby-D!
Re: Overdrive?
when i push the button absolutely nothing happens. i'll try the second part you suggested.
just thinking about it, i had made a thread about my cigarette lighter/power source not working because it keeps blowing fuses. could this be related? are they tied in together somehow?
Current:
Previous:
Old 12-08-2010, 05:42 PM   #21
Re: Overdrive?
The wire harness is tide in together under the dash near the radio, maybe the plug came undone or just losing contact. I have to play with my button sometimes, try pushing it allot it might just be the button.
Old 12-08-2010, 06:09 PM   #22
Murph's Avatar
Region: Maine
Re: Overdrive?
Unless you're running at a higher speed on flat roads, you might not notice a difference as the tranny might not be in your top gear.
Murph's Glassback!
Murph is offline   Reply With Quote
Old 12-08-2010, 08:42 PM   #23
Re: Overdrive?
It could be the fuse...there is a separate fuse for o/d, so I'd start there. If that doesn't do the trick, check your wiring. As said, you'll have to tear apart your radio/shifter area to get to the wiring. If you take the shifter and o/d button apart, be careful not to lose the spring in the shifter handle or tear the wires...they are VERY sensitive.
overdrive The Darkside 2005-2010 Mustang GT 58 02-02-2009 08:27 PM
overdrive Mustang GT HO 1996-2004 Mustang GT 4 05-04-2008 11:19 PM
Using OVERDRIVE jaredp Pre-2005 V6 Mustang 16 01-27-2007 12:36 PM
Overdrive question didnt know where to put this 95 DrOpToP Pre-2005 V6 Mustang 4 02-08-2005 08:36 PM
Question about Overdrive light Twitch Pre-2005 V6 Mustang 6 02-11-2004 04:05 PM
10:10 AM
