4v swap questions - Mustang Evolution
Old 10-20-2010, 09:45 PM   #1
4v swap questions
Ok im new here but not to the muskrat world. Let me start by saying the owner of the company i work for has a 95 v6 that hit over 500hp. It has d1sc procharger, a little shot, gm t-56 trans with hydraulic clutch. Pretty much everything is custom because of the unavailability of parts. Let me tell you he didnt think about cost while doing this car. Long story short after a few years of beating the car it went boom a few weeks ago. So as me being familiar with 4v's owning an 03 cobra that is the swap i want to do. Plus if you owned a 4v before you know why. Long story short i am looking for good info or point me to good info on any issues i might come across, besides the obvious. Take that back anything just in case i did forget something. I will post a link for all you e-thugs that want to call BS. Im not looking to get into a pissing match her I literally joined this forum to get some good info on the V6 side of the house. Thanks for all the help in advance.
1996 Ford Mustang Saleen - Muscle Mustangs and Fast Fords Magazine
blownsnake is offline   Reply With Quote
Old 10-20-2010, 10:07 PM   #2
Re: 4v swap questions
It bolts in...don't see the issue...
Old 10-20-2010, 10:12 PM   #3
Yeah i heard that dohc 4.6 is the most popular bolt on for these engines On a side note probably will have a lot of great v6 parts for sale really soon any questions pm me.
P.s. lowflyn Sonic Blue is my favorite terminator besides Mineral Grey of coarse
Old 10-21-2010, 03:05 PM   #4
upton7's Avatar
wait a minute what are you trying to do?
Old 10-21-2010, 06:08 PM   #5
dropping in a 4.6 4valve into his 95 which used to have a 500hp v6. Already Have a T56 gm trans and a built 9 inch rear end.
Old 10-21-2010, 10:19 PM   #6
upton7's Avatar
oh lol. I thought u were talking about putting 4v v8 heads on a v6 lol.
Old 10-25-2010, 09:28 AM   #7
SaleenFiend's Avatar
Why would we call BS on a 500hp V6 Mustang?? This isn't the first time anyone has seen that. We have some pretty potent sixers on this site.
The swap should be simple as pie as you have most everything in place already.
BTW the car looks good.
Old 10-25-2010, 07:25 PM   #8
silverstangboy's Avatar
not to thread jack, but do alot of people have problems with the 8.8"s?
I keep hearing of folks putting 9"s into SN95's when the 8.8 is a bolt-in.
93 mustang notch
~450hp 331 stroker - Sold
Old 10-26-2010, 06:33 AM   #9
The 8.8s and 9s are pretty much the same rear end give or take some here and there. some people just choose the 9 over the 8.8 based on mere fact as it's somewhat rare (or uncommon) and still stronger. Nobody has a real nead for the 9 over the 8 unless you have a serious launching car.
Old 10-26-2010, 10:58 PM   #10
hottcobra's Avatar
the 8.8 and the nine inch are completely different in every way.
the 9in uses a third member or "center chunk" with spanners to adjust backlash.
where the 8.8 has a carrier style setup and uses shims to adjust backlash.
The 9in is ten times stronger than a 8.8 and great for racers cause if you have other complete center chunks with different gear ratios. you can change your gear ratio at the track on the ground in about 30 minutes with out and special.
The downfall to the 9in is that it's heavier than the 8.8 and it robs more horsepower out of the drivetrain.
A lot of racers are starting to use the Dana 60. As its lighter and robs less power than the 9in, and almost as strong as the 9in.
Old 10-27-2010, 06:43 AM   #11
Had no idea. Thanks Louis.
Old 10-31-2010, 08:51 PM   #12
very cool info
Ask and ye shall recieve
93 mustang notch
Split port swap questions big show 98 Pre-2005 V6 Mustang 13 01-09-2010 02:27 PM
7.5 to 8.8 rearend swap questions... strawdog Pre-2005 V6 Mustang 6 06-18-2009 03:11 PM
swap questions ryanxup Pre-2005 V6 Mustang 10 01-27-2007 11:02 AM
I have a couple 5.0 swap questions colinsv6stang 1979-1995 Mustang GT 5 04-28-2006 12:18 PM
Yup, more v6 to 4.6 swap questions fast64 1996-2004 Mustang GT 10 06-19-2005 01:30 PM
11:37 PM
