v6 to v8 swap - Mustang Evolution
Old 10-26-2010, 05:50 PM   #1
v6 to v8 swap
have 08 v6 want to put 302boss crate motor has anyone done this and problems you ran into
bumlett1 is offline   Reply With Quote
Old 10-26-2010, 06:43 PM   #2
obxdude018's Avatar
Re: v6 to v8 swap
Never have done it, I'm going to be putting the 4.6l in my v6 and I know I will need the engine, tranny, rear end to handle the power, driveshaft, computer, wiring harness and some more things. In the end you will be looking at roughly 10-15k to do that.
obxdude018 is offline   Reply With Quote
Old 10-26-2010, 08:15 PM   #3
Re: v6 to v8 swap
you will need to change the tranny or maybe bellhousing if your 5 speed.
The 4.0L doesn't have the V8 bolt pattern on the bellhousing like the 3.8L/3.9L. If your going carb instead of fuel injected it will be easier. But it isn't a easy job overall.
Straublittleman is offline   Reply With Quote
Old 10-27-2010, 05:41 AM   #4
stampde's Avatar
Re: v6 to v8 swap
It wouls probably be less costly to buy a used GT instead , I recently bought a v6 ,and came across many used GT's in the $15,000 to $18,000 range .....
2011 GT Auto
Old 10-27-2010, 08:25 AM   #5
Re: v6 to v8 swap
i am going carb and i figured about 12,000 just curious about what i might expect. also i cant do it have to have a shop do it just wanted a little knowledge b4, any suggest on tranny typy and rearend
Old 10-27-2010, 09:01 AM   #6
blackonblack's Avatar
Re: v6 to v8 swap
yeah... im with him ^^^
2004 3.9L v6
Black on black on black
MAC Cold Air Intake, 4.10 gears + T-Lok, SCT Tuner, dual H piped flowmaster super 40's
blackonblack is offline   Reply With Quote
Old 10-27-2010, 01:24 PM   #7
Re: v6 to v8 swap
If you want auto stay with the 4r70w and have the j-mod done to it. If you want stick-shift I myself would go 6 speed tremec. Since you're going carb it will be easy to wire in the motor. I can usually wire a carbed motor with to hots and have it running minus the gauges.
Old 10-27-2010, 04:39 PM   #8
94 GT Dawn's Avatar
Re: v6 to v8 swap
I agree it would better to look for a gt than switch all that over...
94 GT Dawn is offline   Reply With Quote
Old 10-31-2010, 05:57 PM   #9
Send a message via AIM to VCS_SSSTANG
Re: v6 to v8 swap
Buy the time a shop gets done raping you, you prob would have been able to buy a small 3 bed room house.
VCS_SSSTANG is offline   Reply With Quote
Old 11-26-2010, 07:28 PM   #10
ROUSHCUPCAR's Avatar
Re: v6 to v8 swap
almost done wit my 2000 3,8 to 4.6 swap. Its a project but in the end i think its gonna be worth it. Not everyone has the know how or the balls to tear apart a perfectly good running car to make it into something they really want. Just do it!
ROUSHCUPCAR is offline   Reply With Quote
Possible V8 Swap? NeedSomeMods Pre-2005 V6 Mustang 5 05-18-2010 02:43 PM
5.4 swap 3.8boii Pre-2005 V6 Mustang 10 05-14-2010 08:38 AM
4.6 to 5.4 swap 1fst5.4stang 1996-2004 Mustang GT 4 05-13-2010 02:22 PM
swap a 98 4.6 into a 95 3.8 Platinum Stang Pre-2005 V6 Mustang 5 06-06-2006 05:58 PM
t5 swap powerhungry966 Pre-2005 V6 Mustang 7 10-19-2005 08:18 PM
09:42 AM
