what is compatible - Mustang Evolution
Old 11-01-2010, 03:14 PM   #1
1996v6stang's Avatar
what is compatible
so i recently f***ed my tranny up, no longer have reverse and it clanks. im just wondering what trannys will directly bolt up and work with my 1996 v6 mustang. i want what ever will just bolt up to the bellhousing.
thanks
billy
1996v6stang is offline   Reply With Quote
Old 11-01-2010, 03:15 PM   #2
Re: what is compatible
Just grab another T-5 out of 94-98 in a junkyard.
Old 11-01-2010, 04:59 PM   #3
is there any way to check the tranny before i buy it to see if its good?
Old 11-01-2010, 07:28 PM   #4
MonteCitan's Avatar
Run the shifter into each gear, turning the input shaft each time to make sure the output shaft actually spins.. and that it doesn't make a grinding noise while doing so..
Beyond that its kind of a crap shoot..
Could see if they forgot to change the fluid.. crack the drain and see if there are numerous metal shavings.. Chances are if the car is wrecked, the transmission is OK. If the car looks to be in OK shape then its either had trans or engine issues
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 11-01-2010, 11:01 PM   #5
Also check the input shaft for play or wobble if it does don't buy it unless you plan on putting a bearing kit in it.
Also if reverse is the only gear you lost then it would be easy to fix with a junk tranny with a good reverse gear because you only have to take the tailshaft apart and a clip and slide the gears off and switch them. Its not as hard as you may think.
Straublittleman is offline   Reply With Quote
Old 11-02-2010, 08:53 AM   #6
T-5s should be rather cheap and are easy to yank out since they unbolt from the OUTSIDE of the bellhousing (who would ever do it the other way... yup newer mustangs do it backwards) so you can have the trans out in no time.
Old 11-03-2010, 09:40 AM   #7
SaleenFiend's Avatar
Rob has two. PM PureVenom
Old 11-05-2010, 11:57 AM   #8
do all t5 trannys have 4 bolts to the bell housing? will all years of them work with a 96 v6? just tryin to make sure before i buy something. and im waitin for rob to pm me back but its been a couple days and i have a set time frame, i need the tranny by next friday so i can have it fixed by early sunday morning.
NEW V6 compatible Exhaust System, w/specially tuned camshaft... RGR Pre-2005 V6 Mustang 26 03-10-2005 04:58 AM
Compatible bodies and engines eddied The Bar 6 03-22-2004 04:29 AM
06:23 AM
