Adjustable Lower Control Arms - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Pre-2005 V6 Mustang
Closed Thread
Old 07-09-2007, 12:43 AM   #1
matthews.stang's Avatar
matthews.stang is unknown around these parts
Send a message via MSN to matthews.stang
So I have been browsing on StangSuspension.com and building for wish list when I came across these lower control arms. Can anyone tell me what the real benefit of these would be on a street car? I want to occasioanlly go to the Auto-X event, but not every week. I also like driving my car really hard sometimes.
matthews.stang is offline
Old 07-09-2007, 07:29 AM   #2
Terminator Owner
SpectorV is just getting started.
Re: Adjustable Lower Control Arms
I think adjustable LCA's are mainly for cars with coil overs as the spring sits on top of the LCA in non coil over setups (OEM design)
SpectorV is offline
Old 07-09-2007, 04:00 PM   #3
bullitt482's Avatar
bullitt482 is unknown around these parts
Go here **********************THE BEST Upper Control Arm Kit on the market**********************
I know it says one thing, but check out where it says how to baseline your car's suspension. There is PLENTY of knowledge on the sight. I know it's mostly drag stuff, but it will help A LOT to help you understand the whole shebang.
I'll try and find some road course/autox suspension info to help you out.
01 Bullitt
bullitt482 is offline
Old 07-10-2007, 08:49 AM   #4
Terminator Owner
I need to invest some time in researching the upper control arms on our cars. I know they bind and I know that urathane or really any upper control arm will also bind and thats just bad... most say rubber HD cobra uppers are the best way to go for the street as they allow flex but help as well (as much as they can) perhaps adjustables that allow the twist to happen freely would remove bind~ just not sure.
SpectorV is offline
Old 07-10-2007, 02:05 PM   #5
Well, I had my car up on a lift today and I got to see all of the control arms so it made it a little easier to understand what was going on.
Old 07-10-2007, 03:10 PM   #6
crazeflier07's Avatar
crazeflier07 is unknown around these parts
Send a message via AIM to crazeflier07
I would imagine that with the LCAs and a pan bar setup it would benefit you with better traction and you probably would have the "lose rear end" feel in turns. I heard they are good for drag but they probably benefit in autox too. Lighter then the stock ones so thats a plus and they look cool. Saw a camaro with a nice suspension set up and he had aluminum control arms in the back and they looked sweet with the car. Make sure you get the polyurethane bushings though.
~Jon~
Sinister Six
1998 3.8L V6
Done So Far:
~CAI, True dual exhaust, UDPs, MGW Shifter, H&R springs, Stage 1 & 2 supension kit, performance rotors & pads, steel braided lines, 1 inch rear spacers, A.R. Rebel 17x9s with BFG rubber! :thumbs2:
crazeflier07 is offline
Old 07-10-2007, 05:17 PM   #7
Terminator Owner
Derlin bushings are better than poly. Also spherical bushings on the LCA's are much better than just sticking poly bushings in a stiff LCA arm.
SpectorV is offline
Closed Thread
Control Arms Y2E0L0L5OGWT 2005-2009 Mustang GT 5 06-20-2007 09:57 PM
Hotchikus lower control arms question dana 1979-1995 Mustang GT 14 02-03-2006 06:58 PM
which lower control arms to get? mild2002gt 1996-2004 Mustang GT 11 01-16-2005 11:54 PM
Lower control arms Rick0636 Pre-2005 V6 Mustang 10 07-15-2003 03:43 PM
09:14 AM
