05 v6 charging issues - Mustang Evolution
Old 11-16-2010, 07:08 PM   #1
obxdude018's Avatar
Ok I have been having this problem for a while, so I will start from the beginning, my car fails to start in the mornings or after a period of longer than 12 hrs. or so. It started about month and 1/2 ago, thought it was just the battery since it was the original battery and it has almost 5 years worth of life, a friend gave me a new battery he bought I replaced it and the car had no problems for roughly 4 or 5 days, then it started again, I replaced the positive terminal, nothing, bypassed the capacitor in the trunk for the amp, and that made it worse (as the capacitor has almost enough power to start the car on its own, I disconnected it to get rid of everything that uses power while the car is in use), then went to a friend's house we checked voltage out of the alt. and we were getting right around 14.8v or very close to that, we stumbled upon something and thought it might be it, with the amp meter around the negative line, we jiggled it and the volts started to flux, so I replaced the negative terminal and upgraded the ground wire that goes to the shock tower with 4 gauge wire and still no prevail, also there is no draw when the car is shut off. I shut off my stereo everynight and it's not a shaker.
obxdude018 is offline   Reply With Quote
Old 11-17-2010, 01:00 AM   #2
Re: 05 v6 charging issues
did you test the voltage when revving the car, maybe the alt isnt charging when its at a higher rpm. try checking the amperage draw during it running and see if there are any high spikes other than when the cooling fan kicks on. but it does sound like the voltage regulator isnt working correctly.
Straublittleman is offline   Reply With Quote
Old 11-22-2010, 09:21 AM   #3
obxdude018's Avatar
Load test came back with "excessive ripple"
Old 11-22-2010, 03:32 PM   #4
I'd go ahead and replace the alt, it does sound like thats the problem.
charging system not working muskrat Classic Mustangs 8 04-12-2008 09:50 PM
A charging system question... silverstang 1996-2004 Mustang GT 1 03-09-2008 07:40 PM
charging system woes Thomas91169 Mustang Audio & Video 15 08-12-2006 12:34 AM
PLEASE Help!! charging issues...91 GT scorpionSStang 1979-1995 Mustang GT 11 02-10-2006 04:56 PM
battery charging problem I_luv_HP&trq Pre-2005 V6 Mustang 20 09-24-2005 02:58 AM
03:00 AM
