gauges reset when started? - Mustang Evolution
Old 11-19-2010, 11:52 AM   #1
A.K.A. Baby-D!
hey guys. my 04 V6 has been starting up kinda weird lately. every time i crank her up all of my gauges go through the 'TEST' where they go all the way up then come back down. at first i was thinking maybe it was a battery/alternator issue because i've seen it do that if i leave my radio on for a while and the battery drains a little but not enough to keep it from starting. but i'm not sure why it would do this every time i start the car??? doesn't matter how long it sits whether it be 5 minutes or over night. could it be possible that i have an electrical issue somewhere?
all input appreciated!
Current:
1989 GT--the project
Previous:
2004 V6--my first pony
1988 GT--July 2010 MOTM
Old 11-20-2010, 05:39 PM   #2
tvsr's Avatar
Region: Nevada
Re: gauges reset when started?
Mine has done that as well, sounds primative but check that your fuses are on right. try disconnecting the battery and putting it back might be a minor malfunction
tvsr is offline   Reply With Quote
Old 11-21-2010, 04:58 PM   #3
A.K.A. Baby-D!
Speaking of fuses... I've also been experiencing problems with my cigarette lighter/power source. In dash and in console. Keeps blowing fuses. And I'm using the same kind of fuse.
I have already disconnected the battery. No change.
Current:
Previous:
Old 11-21-2010, 08:26 PM   #4
tvsr's Avatar
Region: Nevada
if the fuse keeps blowing then its probably the wring voltage there are 5, 10,15,20 and so on the if it keeps blowing the number might be too high. When did this start happening was it after something specific?
Old 11-22-2010, 05:55 AM   #5
A.K.A. Baby-D!
nothing specific that i could point out. the fuses for the power sources are 5v i think? what ever was in there was what i used again. and the first one that blew was the one from when i got the car so i would think it was right. i've changed the fuses 3 times and after plugging my phone charger in it would blow after about 5 minutes.
Current:
Previous:
Old 11-22-2010, 07:14 AM   #6
if you remove the battery it will do this, sounds like your battery is going bad or the alternator~ keep an eye on it or go get the battery tested.
Old 11-22-2010, 07:21 AM   #7
A.K.A. Baby-D!
thx spec. i'll get the battery & alternator checked.
Current:
Previous:
Old 11-22-2010, 07:29 AM   #8
I could be wrong but its free to check the battery most times, you can do it yourself with a power monitor~
Old 11-22-2010, 07:55 AM   #9
A.K.A. Baby-D!
yea.. i just find it odd that even after sitting for only 5 min. or so the gauges will still reset. in that case, wouldn't it be dead after sitting over night?
thats why i skipped over the battery/alternator part.. but its still worth checking.
Current:
Previous:
95 GT 5.0 Viper Alarm RESET!! chris7869 1979-1995 Mustang GT 5 02-14-2008 10:11 AM
trying to get something started Kyle Regional Mustang Discussion 0 08-25-2006 08:31 PM
reset ecu: how? tedness Pre-2005 V6 Mustang 5 07-04-2005 11:10 PM
Vote!! Top100 Reset! Brent The Bar 61 03-02-2005 10:31 PM
getting started dansmustang 1996-2004 Mustang GT 2 04-19-2004 12:59 PM
06:05 PM
