Mustang v6 good cheap setup - Mustang Evolution
Old 11-26-2010, 10:29 AM   #1
Qwik Four Six's Avatar
Hey, I've got a 1997 mustang v6 5 speed. I was looking for a good setup for the rear end. Still got the 7.5. Maybe get a t loc and some gears and a tuner for it?
Qwik Four Six is offline   Reply With Quote
Old 11-26-2010, 08:44 PM   #2
Re: Mustang v6 good cheap setup
Yes that would work great. Many have had it done and are very happy with the results. Keep in mind gears/tlok don't add hp, but better distribute power throughout the powerband giving you much improved acceleration, launches, and 2 wheel burnouts
Gears are about $150 and and tloks are ~$200. Tuners are $379 and installs range from $300 to 500+ depending on the shop. I'd recommend getting them professionally installed. Gear installs require a lot of attention to detail, a good amount of precision, and patience. Experience is key since any slight mishaps can cause grinding, rubbing or larger problems in the future.
Typically manuals favor 3.73's and autos stick with taller 4.10's. You can run 4.10's but keep in mind that 1st may become "useless" and mpgs will decrease slightly, ~.5-1mpg on the highway. Your gas mileage will probably rise slightly in the city. I'd say the slight loss in highway mpgs is worth the performance gain.
Another option is to look for an 8.8" rearend from a 94-98 GT or Cobra. The 8.8" is much stronger and comes with a limited slip differential (tlok). Depending on the condition and mileage of the rearend, you may want to install new gears and rebuild your tlok. American Muscle sells rebuild kits with new carbon clutch discs, shims, and s-spring.
Check craiglist, ebay, and local salvage yards for wrecked v8 cars if the larger 8.8" interests you.
Old 11-27-2010, 02:40 AM   #3
I was looking into getting a foxbody 4 cyl conversion, so I'd have a fast car, but cheap insurance. Or change motor and transmission out in mine, but once I started looking into that, it got costly. So I was considering a fox body, or just doing small things to my car. What do you think? Also, if I were to get a 5 lug 8.8 with abs, would it go right under the car with no problems? Or would I have to change things out?
Old 11-27-2010, 04:12 AM   #4
Its a direct swap, it goes right in without any problems.
Straublittleman is offline   Reply With Quote
Old 11-27-2010, 11:00 AM   #5
Alright. Thanks.
This setup sounds surprisingly good gmantheman 2005-2010 Mustang GT 3 10-20-2008 10:26 PM
good rear suspension setup? notstock02gt 1979-1995 Mustang GT 6 05-01-2007 06:08 PM
Anybody in Cali want a Cheap Cobra (19K Cheap) bluemustang The Bar 14 04-06-2007 02:19 PM
Is this a good setup for my 95 Cobra 302?? black95SVT 1979-1995 Mustang GT 9 11-21-2005 04:40 PM
good audio setup for expansion? tedness Mustang Audio & Video 9 01-07-2005 12:35 AM
09:30 PM
