Mustang quality? - Mustang Evolution
Old 12-06-2010, 04:47 PM   #1
tvsr's Avatar
Region: Nevada
Mustang quality?
Is it me or do mustangs brake down a lot? I don't know about anyone else but there is always a problem with my car its never ok i fix it 3 months later theres a major problem. its a 99' I dont know if its the model year or what, what abaout you guys, havin a lot of problems?
tvsr is offline   Reply With Quote
Old 12-06-2010, 04:50 PM   #2
Re: Mustang quality?
How many miles are on it?
Old 12-06-2010, 04:51 PM   #3
tigercrazy718's Avatar
i know mine is way newer but i have had exactly 0 problems with my car that werent caused by me lol
2008 V6
204 RWHP
If you wreck and kill yourself trying to jerk off on the way to her house I will put it all over the internet.
tigercrazy718 is offline   Reply With Quote
Old 12-06-2010, 05:36 PM   #4
SVTCOBRA's Avatar
Well there are many variables to consider.
Did you buy it new or used?
How may miles are on it?
How well have you maintained it?
At the body shop I work at it doubles up as a mechanic shop as well. But in the seven months Ive been working there I have not seen a single Mustang in any of the mechanic bays. Ive also have not had a single problem with my Mustang except for oil brakes and rotors.
A Super Torque Ford!
"The problem with socialism is that eventually you run out of other people's money." (Margaret Thatcher)
SVTCOBRA is offline   Reply With Quote
Old 12-06-2010, 05:54 PM   #5
I have had my 2004 for a little over two years. I have only replaced the alternator and a coil pack.
My old black '01 V6 that I for two years only had to have a clutch and alternator replaced.
Both daily drivers and no major issues.
Old 12-06-2010, 07:11 PM   #6
v0nz's Avatar
I had to get my tranny rebuilt other than that, I love my car.
Proud 2004 v6 3.8L Pony Owner.
v0nz is offline   Reply With Quote
Old 12-06-2010, 07:19 PM   #7
Auto or 5 speed?
Old 12-06-2010, 07:26 PM   #8
v0nz's Avatar
Auto or 5 speed?
Auto...
And I am the enmity of most mature mustang drivers, Im a kid so I race around a lot and treat the transmission like **** but I wash her every week n wax every other and I of course have bolt-ons, exhaust, n all that good stuff.
Old 12-06-2010, 07:30 PM   #9
I'll never buy a Ford auto pre 2005. They suck
Old 12-06-2010, 07:42 PM   #10
v0nz's Avatar
Sadface, specially v6..
Old 12-06-2010, 07:45 PM   #11
Scrshaw's Avatar
My 01 V6 has been pretty trouble free except for normal maintenance issues. The only major problems I've had with it (blown rear last year and transmission this year) were due to my beating the crap out of it at the track every weekend for the last 6 years. It's got over 100,000 miles on it and its still going strong.
2001 Zinc Yellow V6 3.8L Coupe
65mm TB & Spacer, K&N FIPK CAI, Trac-loc, 4:10 Gears, Custom tune from Pro-Dyno, LT Headers, H-Pipe, High-flow Cats, Flowmaster 40's, UD pulley's, Upper and lower rear control arms, Drag launch springs, Line-locks, Custom Built 4R70W Trans,2500 RPM Torque Converter, Trans Cooler, 190 LPH fuel pump
Scrshaw is offline   Reply With Quote
Old 12-06-2010, 07:59 PM   #12
I have owned two V6 Autos. I know how bad they suck lol
Old 12-06-2010, 08:14 PM   #13
I own one now, sadface.
Old 12-06-2010, 08:18 PM   #14
Good luck
Old 12-06-2010, 09:28 PM   #15
To the OP:
It really comes down to how the car has been treated during it's time on the road. If you weren't the original owner, then previous owners may have not taken care of it properly, leaving you with the problems.
Mustangs are very reliable cars with little problems if maintained properly. I bought mine at 17k miles and it's got 61k now...not one problem, only routine maintenance.
Old 12-06-2010, 09:33 PM   #16
tvsr's Avatar
Region: Nevada
well mine got 134xxx miles on it at about 130xxx i replaced the motor and tranny wit a 02 motor v6 but ive changed my alternator,entire ignition system, water pump, radiator, calipers, rotors, i could go on forever I keep it very well maintained I don't know how the previous owner kept it but its been like two years and every month or so i got to fix something. the car is good now (thank god) but my rpm need rises and drops between 1000 and 500 rpm at idle. I was thinking of selling it if it gave me more problems
Old 12-06-2010, 09:41 PM   #17
Yah after complete swaps it can be tough to not have some sort of problems...there are so many components that are changed and if one wasn't done correctly or if something was forgotten then you'll have a string of problems.
Old 12-06-2010, 09:48 PM   #18
tvsr's Avatar
Region: Nevada
any idea what the unstable rpm at idle can be?
Old 12-06-2010, 09:53 PM   #19
Could be your IAC (Idle Air Control), maybe a dirty MAF (mass air flow sensor), Throttle Positioning Sensor, vacuum leak, I'd check all those things and see if the idle improves.
Old 12-06-2010, 09:59 PM   #20
tvsr's Avatar
Region: Nevada
i think it might be the IAC or the throttle positioning sensor ill look at that thanx sonicpony
Old 12-06-2010, 10:06 PM   #21
No problem, definitely take a look at those parts and check for buildup or if they need to be adjusted. Sometimes something as simple as that will do the trick
Old 12-07-2010, 08:44 AM   #22
A.K.A. Baby-D!
my 04 hasn't given me any major problems. only regular maintenance. and changed parts due to wrecks. but it has been a great car for me. she has about 110k miles now. i believe that ANY car can be a great car as far as reliability when taken care of properly.
Current:
1989 GT--the project
Previous:
2004 V6--my first pony
1988 GT--July 2010 MOTM
Old 12-07-2010, 08:52 AM   #23
My 94 has 125,xxx miles on it and only problem with it is the auto tranny that doesn't belong in it and normal maintenance.
Straublittleman is offline   Reply With Quote
Old 12-07-2010, 09:04 AM   #24
ive never had any major issues on any of my 3 mustangs (97, 01, 03). The 01 did have a clutch vibration issue but nothing major.
its all in how its taken care of as well as how work done to it is done. Just because someone "fixes" something doesnt mean they did it right or fixed the actual issue.
Dont blame it on Ford, it wouldnt matter what you drove its just something that happens.
People always blame it on the auto manuf rather than who did the work or not taking proper care of their vehicles. No matter what you drive parts will mess up~ its just how it is
Old 12-08-2010, 05:07 AM   #25
Talking Re: Mustang quality?
I really don't think so. I should knock on wood first.... My 3.8 has 200K miles+ and it has never broken down. I have just replaced pieces worn out and thats it. Although I do not allow a squeak, tap, or anything at all go without emediate attention some how. All in all, my 1997 V6 runs pristine. Today anyway.
Old 12-08-2010, 11:33 AM   #26
SVTCOBRA's Avatar
Well not to bring any bad news to the table, but Ive seen the first totaled 5.0 at work last night. Man that sucked to see and I don't think me calling dibs on the engine helped either.
Old 12-08-2010, 11:43 AM   #27
A.K.A. Baby-D!
ouch!
Current:
Previous:
Old 12-08-2010, 11:46 AM   #28
1234's Avatar
The only things ever broke on my car were from me and a quarter mile of track.
Old 12-08-2010, 01:53 PM   #29
Send a message via AIM to VCS_SSSTANG
Nothing on my car has actually broken without reason...
Open diff broke - I blamed that on vortech
motor started knocked after I sucked up about 1/2 gallon of water - I blamed that on the rain (and needed an excuse to pick up a forged super coupe motor) turns out the stock motor just needed some wd40 and its currently running in another car.
VCS_SSSTANG is offline   Reply With Quote
Old 12-08-2010, 04:31 PM   #30
upton7's Avatar
My v6 never had a problem when I owned it, until I sold it. They guy I sold it to has had issues with it daily. I think It just got mad I sold it. lol My gt has never had a problem.
Old 12-08-2010, 07:46 PM   #31
tvsr's Avatar
Region: Nevada
I don't know I take care of it, i only put the best of the best in that car everything synthetic, don't really race it, always doin upgrades. It started after the engine overheated and i had to replace it, i changed everything that could have caused it but it was going to inevitably die. well Its good now so we'll see, If something happens to it by 2011 ima sell it.
Old 12-08-2010, 08:08 PM   #32
MonteCitan's Avatar
The only things I've broken on any of my many mustangs in the past..
Were directly related to my left and/or right foots
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 12-09-2010, 04:42 PM   #33
My parents have an 01 v6, it has been a great car. It has alittle over 100,000 miles on it and the only thing that has been replace is the coil pack. Just need to keep you maintanence up and the reliabilty will be awesome.
1993 Ford Mustang 5.0 GT convertible all stock
2012 Ford Mustang 3.7 Coupe
Dustin f2504x4 is offline   Reply With Quote
Old 12-09-2010, 11:52 PM   #34
upton7's Avatar
You replaced the engine?
Old 12-10-2010, 12:28 AM   #35
1ijack's Avatar
Send a message via Yahoo to 1ijack
I have a 99 gt and besides the horrible person who owned it before me and neglected the girl she has been very good to me. No major issues yet, going through and replacing old worn out parts of a maintenance program that should have been followed before.
The Mustang Mafia
"Join the family, if you dare"
www.themustangmafia.com
1ijack is offline   Reply With Quote
Ebay light quality Foxone Mustang Audio & Video 9 09-26-2009 03:31 PM
Ford...Quality is job... PureVenom Pictures and Videos 15 06-24-2008 10:29 PM
The Difference Between DVD Quality and High Definition Quality Brent The Bar 20 05-26-2007 03:33 PM
The need for quality personel !!! Danger Dude The Bar 6 12-15-2004 03:39 PM
We need to know about quality shops in your area!! Danger Dude Regional Mustang Discussion 2 10-27-2003 04:59 PM
08:02 AM
