rear brake rotor hot - Mustang Evolution
Old 12-10-2010, 10:49 AM   #1
My rotor gets hot and there is alot of brake dust on my wheel. Also I smell brake fluid while driving. I suspect the caliper is stuck or the slider has seized up. any Ideas?
mightymav72 is offline   Reply With Quote
Old 12-11-2010, 01:24 AM   #2
tvsr's Avatar
Region: Nevada
Re: rear brake rotor hot
Unfortunatly Ive only had expirience with front brakes. However if you smell brake fluid you are most likely leaking it. There is a hose that leads from your car to the caliper if this hose is ripped or the screw attaching it the caliper is loose then you get leaks, can also come from the caliper pistons. I recomend taking out ur tire having someone look at it while you pump the brakes then you can see where the leak is comming from
tvsr is offline   Reply With Quote
Old 12-11-2010, 11:03 AM   #3
stampde's Avatar
got to take it apart and find out , caliper slides are probably seized up, u can pick up a caliper at a parts store fairly cheap ..........and since your smelling brake fluid i'd pick up a new hose also / if you have the cash you might just want to do both sides , new brakes ,hoses,and calipers .............
2011 GT Auto
Old 12-11-2010, 01:57 PM   #4
You guys were right, however there were no leaks. I think the friction on the 500 mile trip heated the brake fluid and thats what I smelled. Caliper brackets were $20 each at Autozone. Thanks for the help.
Old 12-11-2010, 07:04 PM   #5
tvsr's Avatar
Region: Nevada
Glad to help. so it was the caliper brackets?
20" rims, Low profile Falken tires, dropped, AM Cold Air Intake, MSD Super Conductor Wires, Flowmaster muffler, GatorBack Belt, Vented cross cut Rotors, Blacked out lights, BEM Reverse Glow Gauges...
Old 12-13-2010, 08:07 AM   #6
Ninethourpm's Avatar
I had the same problem and found the slider bolt was seized making the caliper stick. By the time i found it the brake chucked the pad backing and put the piston into the disk.
2000 silver 3.8 5 speed,smoke tint,cold air intake,MAC Long tubes, MAC Catted H,MAC GT catback, SCT Livewire w/ Bamachips tune,
17x8Fr 17x9Rr Bullit Wheels More to come......
96 honda magna vf750, K&N, Vance and Hines pipes Rejetted carbs
Ninethourpm is offline   Reply With Quote
Old 12-27-2010, 07:34 PM   #7
Yep one of the sliders was seized ,in the closed position of course. Ruined the pad and rotor, but not the caliper. Now I can upgrade to slotted/drilled rotors.
Brake Rotor Concern runvsofthisbull Pre-2005 V6 Mustang 20 03-30-2010 08:01 AM
Roush 13-inch Rear Rotor Replacements? 3ricchu 1996-2004 Mustang GT 2 11-16-2009 07:14 AM
01 GT rear rotor issues Ride1331 1996-2004 Mustang GT 3 04-15-2009 03:59 PM
Brake rotor question colinsv6stang Pre-2005 V6 Mustang 5 03-29-2006 09:33 AM
Rear brake seized Danger Dude Pre-2005 V6 Mustang 9 05-24-2005 09:11 PM
10:35 AM
