v6 turbo - Mustang Evolution
Old 12-12-2010, 07:52 AM   #1
v6 turbo
I have a 2000 V6 mustang. I have the opportunity to buy a turbo off a 01 thunderbird. Will this swap work? Are there any problems I might run into?
Would I need the computer out of the t-bird?
Would it be worth it HP wise? Thanks.
pringle9666 is offline   Reply With Quote
Old 12-12-2010, 12:31 PM   #2
MonteCitan's Avatar
Re: v6 turbo
What year tbird?
If its an older turbocoupe you'll have a lot of fighting to do, as that was initially a 4 cylinder
If it were a supercoupe and you're getting a SC not a turbo.. That would be an easier swap but still wouldn't be easy
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 12-12-2010, 01:08 PM   #3
I had looked into the Tbird SC already but found out it was going to be really hard to do so I decided not to.
Old 12-12-2010, 04:13 PM   #4
Re: v6 turbo
Yah if it's the turbo coupe then it's a 4 cylinder that made 145 and 155hp (1985). I'd definitely let that one slide.
You could look into a M90 supercoupe swap, but I'd only consider it if you have a pre 99.
The biggest issue for me with the thunderbird supercoupe is that the 3.8 in those cars are single port engines...the 99-04 3.8's are split ports. You are basically going backwards in order to get a half a step forward. If you have a pre 99 3.8 the swap is still a fair amount of work but your gains will be much better. I'd almost look for the entire engine at that point. They came with a forged crank and upgraded heads/pistons. Even so, you'll need the complete engine, wiring and ecu.
2.3 Turbo MC770 2.3 Mustang 3 12-03-2010 01:18 PM
turbo for 94 3.8L Mikemx250 Pre-2005 V6 Mustang 3 09-02-2008 01:41 PM
04 v6 turbo....help Big Nick Pre-2005 V6 Mustang 13 07-26-2008 12:37 PM
turbo ? Z-EATER General Car Discussion 7 08-20-2007 08:11 AM
Turbo!!!! steedav6builder Pre-2005 V6 Mustang 16 08-20-2004 11:13 PM
07:39 AM
