UDP or not? - Mustang Evolution
Old 12-12-2010, 12:21 PM   #1
03blumist's Avatar
UDP or not?
i was talking to a guy the other day and i said that i was thinking about getting a pulley and he told me it was a waste of money and that the dont work. is that true or not?
03blumist is offline   Reply With Quote
Old 12-12-2010, 12:43 PM   #2
MonteCitan's Avatar
Re: UDP or not?
I don't have experience with the V6 UDPs but..
1) I've seen cranks break using these on the 4.6..
2) If you want to go with a blower in the future, you'd have to remove it
3) I've been in several before/after, in my opinion, the SOP gain does not outweigh the downsides..
and 4) By doing this you're slowing down the speeds of the accessories which were designed to work at factory RPMs.. IE : water pump, alternator, etc.
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 12-12-2010, 03:57 PM   #3
Re: UDP or not?
^^^All this is very true.
There are quite a few people out there who have had their cars dynoed before and after a pulley install and showed some gains...~7-10 rhwp (this of course is based off dynos and dyno conditions, environment, weather, controlled and uncontrolled variables pertaining to the car, and many other variables involving dyno runs)
Not bad, but as said, if you plan on supercharging it'll have to be removed, and you're altering the normal speeds/patterns at which OEM parts run.
For the 99-04's a UDP from ASP Racing is 225...I'd personally save up for a tuner or gears/tlok, hell maybe look into a windstar intake if you want an engine mod.
Old 12-12-2010, 11:53 PM   #4
03blumist's Avatar
Re: UDP or not?
im gonna go turbo but i was wondering if it was worth it to do it
Old 12-13-2010, 07:20 AM   #5
Re: UDP or not?
a V6 will gain about 5-7rwhp/tq there about wtih a 25% underdrive crank pulley~
in 00 or 01 they changed from internal balance to external or visa versa on the 3.8L motor. Keep that in mind there two be one for the two year sets. Overall I had one on my 01 and I felt it was worth 200 bucks~ good investment and easy to install (impact needed). When you install it if its not put on with the RECOMMENDED tq specs it can back our not go in enough and cause misfire error codes or worse.
fs 99-04 25% udp mustang0386 Mustang Parts for Sale and Wanted 1 03-04-2007 02:48 PM
udp mustang0386 Pre-2005 V6 Mustang 6 12-18-2006 01:02 PM
UDP Kit crazeflier07 Mustang Parts for Sale and Wanted 3 04-21-2006 06:49 PM
UDP Question 232stang01 Pre-2005 V6 Mustang 6 04-14-2005 07:09 PM
CAI V. UDP SixSilver Pre-2005 V6 Mustang 23 08-09-2003 09:55 PM
01:28 PM
