Squeaking noise - Mustang Evolution
Old 12-19-2010, 05:49 PM   #1
Nog51's Avatar
Squeaking noise
Recently it has been colder outside than normal and ever since ive been hearing a squeaking noise really high pitched. I figured it was just the belt but im not too sure if its that or if its my water pump like a few other ppl are suggesting. Can anyone help?
Nog51 is offline   Reply With Quote
Old 12-19-2010, 07:10 PM   #2
junoS197Bl08's Avatar
Re: Squeaking noise
thats definately possible, have you done anything to your car over the summer months? like any additions or work
2008 V6 Windveil Blue with 5spd standard transmission-pony package, replica rims, shorty antenna
junoS197Bl08 is offline   Reply With Quote
Old 12-19-2010, 07:15 PM   #3
Nog51's Avatar
Uhh recently changed alternator, oil, spark plugs and wires, coolant and things lik tht
Old 12-19-2010, 07:53 PM   #4
Re: Squeaking noise
umm well, I would check over the bolts for the alternator depending on when you put it on. The only reason I say that is cuz sometimes when people bolt stuff on in the summer they think its tight and then when a cold winter day comes around everything has contracted a lil bit and a bolt or a belt will be just a hair loser, possibly causing some squeaking. Its just hard to tell without hearing it, its still very possible that its from your water pump.
What yr is ur mustang?
Old 12-19-2010, 10:43 PM   #5
Re: Squeaking noise
Well if it is a belt squeaking try using an old mechanics trick of useing a bar of soap on the inside of the belt while it is running. Only use a bar of soap or a candle the wax will stop it from squeaking for a bit.
Straublittleman is offline   Reply With Quote
Old 12-20-2010, 11:03 AM   #6
Nog51's Avatar
Ok yah ill try that soap trick and its a 2002. I spoke to one of my dads friends and he said its probably the cold weather makin the belt contract or ita making it dry. I want to test my pump for a leak but im not sure how to
Old 12-20-2010, 11:29 AM   #7
Re: Squeaking noise
All water pumps i've seen have a hole "weap hole" in the side where the bearings are, if its bad it will leak from there if it isnt leaking then its most likely not bad.
Old 12-20-2010, 11:31 AM   #8
Nog51's Avatar
Ohh alright cool. Ill check it out. Thanks
Old 12-20-2010, 06:43 PM   #9
bobby02V6's Avatar
Re: Squeaking noise
If none of that works, you could check your cam synchronizer, my 2002 had that go bad last month and it caused a pretty bad engine squeak.
2002 V6... CAI, Pypes Dual Exhaust, SCT Tuner
bobby02V6 is offline   Reply With Quote
Old 12-20-2010, 09:30 PM   #10
Nog51's Avatar
Ok will do, thanks
Old 12-20-2010, 09:38 PM   #11
Re: Squeaking noise
let us know if you figure out what it is
Old 12-21-2010, 08:35 AM   #12
Nog51's Avatar
Jus got done checkin everything out and its doin fine. Checked for leaks and did that soap thing and came to the conclusion it was the belt. Thanks for the advice guys!
Old 12-21-2010, 08:38 AM   #13
Re: Squeaking noise
belts in the cold make more noise until they warm up
Old 12-21-2010, 09:18 AM   #14
Try some belt conditioner. Cheap fix. Soap works too and that's a real cheap fix
bad squeaking noise on 3.8 01' mustang jumpman1203 Pre-2005 V6 Mustang 9 07-27-2015 01:03 AM
Clicking Noise kind of Squeeky Noise... braumab 2005-2010 Mustang GT 23 06-29-2008 11:24 PM
To get rid of squeaking... crazeflier07 Pre-2005 V6 Mustang 0 08-08-2007 08:14 PM
Squeaking Noise joekool9 Pre-2005 V6 Mustang 3 08-03-2004 09:38 AM
can't stop doors from squeaking stangracer Mustang Audio & Video 11 11-11-2003 11:08 AM
03:36 AM
