Passenger side rear floor board soaked? - Mustang Evolution
Old 12-22-2010, 07:48 PM   #1
Hey all,
I've got an 02 convertable mustang and my passenger side rear floor is soaked? Everything else is dry. Nothing on the sides or near the rocker panels.
Thought maybe my daughter spilt something but it's been like that for a while.
Cause of rain? Don't have a clue but it's that one spot and haven't seen any water off the ragtop or anywere else.
Any ideas?
I'd appreciate any help thx...
hightower is offline   Reply With Quote
Old 12-22-2010, 07:51 PM   #2
Titus Wadicus
svtlx's Avatar
Re: Passenger side rear floor board soaked?
Originally Posted by hightower View Post
Hey all,
Any ideas?
you have a blown heater core (has a hole in it)....
Old 12-22-2010, 10:09 PM   #3
iwannagofast's Avatar
or if you were runnin ur a/c lately, probably not too likely since it is december, the drain hose could be clogged
iwannagofast is offline   Reply With Quote
Old 12-22-2010, 10:16 PM   #4
Titus Wadicus
svtlx's Avatar
Hey all,
Any ideas?
i just noticed you said "rear" floor board...forget i said heater core. idk wut it is.....
Old 12-22-2010, 10:18 PM   #5
my 04 vert does the same thing, thought maybe it was a small hole in the lining near the window but patched that up and still water in the back passenger floor.
Xan Powers is offline   Reply With Quote
Old 12-22-2010, 10:20 PM   #6
Titus Wadicus
svtlx's Avatar
now im really curious...and i dont own a vert.
Old 12-23-2010, 01:07 AM   #7
Look under the car where the rear floorboard is and you should see a drain plug type hole. There should be a plug there but sometimes they come out and that will cause your floor to get wet when you drive on wet roads. Thats the only thing I can think of that would be doing that.
Straublittleman is offline   Reply With Quote
Old 12-24-2010, 08:55 PM   #8
Had the same problem with my 03 convert. Searched internet websites and found may have the same problem. I followed a suggestion and drilled a 1/4" hole in the body pan frame rail just below the side scoop trim. Supposedly the water enters around the rear side window and eventually collects in the pan frame rail and leaks in where the floor pan joins the door sill. i didn't notice it being wet by the door sill but since i drilled the holes i has been thru a rain storm and stayed dry. Good luck
03 CONVERTABLE is offline   Reply With Quote
Old 12-24-2010, 11:45 PM   #9
Thx all will give it a go if this rain ever stops!
Old 12-29-2010, 05:54 PM   #10
Kingkong707's Avatar
Did you find a solution to your problem cuz I have the same one wanted to know what you did to fix it.
Kingkong707 is offline   Reply With Quote
Old 12-29-2010, 08:36 PM   #11
Hopin to look tomorrow,haven't had a chance. Weather,work,etc.
I will post as soon as i find out.
Old 01-09-2011, 07:22 PM   #12
So far this is what i've been able to come up with, since we just got six inches of snow last night, no garage to work in and it's winter up here eh?
there is a design drain hole in the frame rails just ahead of the the rear wheels. When the water drains out of that hole, it will back up into the frame rails under the door. It would then leak through a seam where the floor pans join the frame rail (under the door).
What worked for me was to throughly reseal the entire seam.
Now i read this on a link somewhere and i'm hoping this will work.
Kingkong 707 if you get this done before i do which i'm sure you probably will.
Let me know how you made out.
Good Luck bro.
B.t.w. I've read a few links where people have been drilling holes.
I'm not into that. If it worked fine before there's gotta be a way to fix it...
Old 01-10-2011, 10:44 PM   #13
http://www.google.com/m/url?client=s...ixCk8agFJa0Scw
Old 01-10-2011, 10:47 PM   #14
Hightower this is very helpful tread I found read it completey and look at the pics and let me know what you think but I think your idea is the best one I just haven't had the time to give it a go but will keep you posted thank you
Old 01-11-2011, 02:03 PM   #15
That's the same one.
Old 01-11-2011, 06:04 PM   #16
O I see lol well will give it a try on the weekend see how it goes but I'm not that familiar with any of this so it will be first
Passenger Side Headlight Goes out. GT_Miami 2005-2010 Mustang GT 12 07-07-2015 01:30 AM
passenger side door rattle buzz8907 Mustang Audio & Video 8 08-31-2010 10:50 PM
Passenger side rear end squeak?? SuperDave2010 1996-2004 Mustang GT 4 03-09-2010 02:18 PM
Passenger side power window motor replacement jaykay 1979-1995 Mustang GT 1 10-18-2008 03:40 PM
Passenger Side Power Window Not Working louie7600 General Mustang Discussion 1 07-27-2008 08:36 PM
01:49 PM
