Engine Stutter - Mustang Evolution
Old 01-03-2011, 10:27 AM   #1
bobby02V6's Avatar
Engine Stutter
Hey everyone,
I have this problem with my engine that started recently. While driving, at about 3.5k RPMs, the engine starts to hesitate and the car bucks real bad. There are no other driving problems until that RPM level it seems.
I recently replaced my cam position sensor and was wondering if maybe I didn't get it timed right when I put the new one in, or maybe something else is going wrong.
Any input would be appreciated, Thanks
2002 V6... CAI, Pypes Dual Exhaust, SCT Tuner
bobby02V6 is offline   Reply With Quote
Old 01-03-2011, 11:22 AM   #2
Re: Engine Stutter
I dont know anyting about installing new cam sensor but my car reacted that way once when a clamp came off of the CAI near the throttle body making a 1/2" gap. Vacuum line leak or loose tubing when working on car?
Old 01-03-2011, 05:26 PM   #3
Fuel filter
Old 01-03-2011, 06:49 PM   #4
bobby02V6's Avatar
Re: Engine Stutter
I was thinking fuel filter too, but I thought that because it started as soon as I replaced the synchronizer that it might have something to do with that. But I was also thinking that if the cam synch was off then it wouldn't run at all.
I guess my next step is to change the fuel filter and hope for the best.
Old 01-04-2011, 08:32 AM   #5
Re: Engine Stutter
i would figure a bad or miss-installed cam sensor would trigger a code, plug up your tuner and read the codes to see if anything is there even though you dont have a CEL light
Old 01-05-2011, 12:36 PM   #6
bobby02V6's Avatar
Re: Engine Stutter
So I changed the fuel filter yesterday and the problem is still there. I also scanned my computer and it wasn't giving me any codes to work with.
When I was driving it today I was just trying to see what caused it. And from a stop, it will go from idle to around 5k Rpms and then shift without problem. But on the highway it will start hesitating at around 3k. I can't understand it, any other ideas?
Old 01-05-2011, 02:22 PM   #7
Re: Engine Stutter
if it just started after the cam sensor install revisit the work and check over everything
Old 01-05-2011, 09:38 PM   #8
Re: Engine Stutter
Does it feel like it's surging at certain rpms?
Also, is your car an auto?
Old 01-05-2011, 11:41 PM   #9
Blogger
99ford's Avatar
Re: Engine Stutter
^ Yeah it wouldn't hurt to do that. In addition how many miles are on the car? If you have say 85K plus, have you replaced the plugs and checked the coil packs?
Old 01-06-2011, 08:36 AM   #10
MonteCitan's Avatar
Re: Engine Stutter
Make sure you didn't damage any of the teeth on the reluctor ring when installing the sensor
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 01-10-2011, 01:37 PM   #11
bobby02V6's Avatar
Re: Engine Stutter
Well my coil pack was replaced about a year ago, but nothing was done with the plugs or wires. My car is an automatic with about 75,000 miles on it.
The only reason I can't understand this is that I would think that if the cam synch was off, it would cause problems across every rpm level and not just high rpms.
I guess I'll just have to check my work and make sure I got it timed right. Thanks for all the input.
Old 01-13-2011, 09:49 PM   #12
Re: Engine Stutter
Yah check that for sure. I only asked if you were an auto because my sister had an impala that had the same issues...surging in the higher rpms...and it was the transmission. I would hope that isn't the case since your car only has 75k miles but you never know...definitely check your cam synch and such first, then if it continues, consider getting a diagnostic for your transmission.
Old 01-13-2011, 10:41 PM   #13
First of all,why was the cam sensor replaced? Was it to correct this issue or another issue?
Alscobra is offline   Reply With Quote
Old 01-14-2011, 10:13 AM   #14
blackonblack's Avatar
Re: Engine Stutter
camshaft sensor. i had the same problem. does your exhaust putter when you try to accelerate?
2004 3.9L v6
Black on black on black
MAC Cold Air Intake, 4.10 gears + T-Lok, SCT Tuner, dual H piped flowmaster super 40's
blackonblack is offline   Reply With Quote
Old 01-18-2011, 11:41 AM   #15
Re: Engine Stutter
I had the same problem and it was just the coil pack. it would run fine if i gas hard but if i was just going down the highway at a idle it would sputter a little.
GTV6Edition is offline   Reply With Quote
Old 01-18-2011, 11:48 AM   #16
ibleedblue65's Avatar
Sounds like you may have a coil breaking down. If, when you load it up it gets worse, us the coil. Go find a hill get it up in fourth and roll into the pedal without causing a down shift, if it starts missing you have a coil breaking down.
ibleedblue65 is offline   Reply With Quote
Engine noise from COLD engine 03GreyMach1 1996-2004 Mustang GT 10 03-14-2008 08:40 PM
engine swap 1989 to 1992 4 cyl engine dannyc1992 General Mustang Discussion 0 02-08-2008 02:59 PM
Engine Swap/ Engine Shakes too_cool_mitch Pre-2005 V6 Mustang 2 02-28-2006 03:01 PM
What's different about this engine? lowflyn The Bar 11 12-04-2005 12:22 AM
My new engine fast64 The Bar 3 09-09-2003 05:18 PM
09:42 PM
