supercharger off a Thunderbird - Mustang Evolution
Old 01-04-2011, 04:48 PM   #1
would the S/C off a 95 T-bird fit my 95 v6 stang?
i have a super snake ring tone on my phone and the supercharger sounds so amazing i want to do it to my car.
95white is offline   Reply With Quote
Old 01-05-2011, 07:14 AM   #2
Re: supercharger off a Thunderbird
nope, to much work so dont waste time/money on it
Old 01-06-2011, 05:04 AM   #3
Awww come on SpectorV!!!
But really I was going to do the same thing, had everything but a tune for the computer. It does cost way to much and you'll never be satisfied with it. If you really really really want to do it then you need everything from the t-bird that includes motor, complete wire harness, fuel pump, and any sensor under the hood. You also need the inter-cooler and piping, radiator. You will need a longer throttle cable and modify your brake lines at the master cylinder for clearance
Straublittleman is offline   Reply With Quote
Old 01-06-2011, 07:46 AM   #4
yea, I just get tired of posting up that you need everything etc etc lol.. I wish it were simple butits not, plus its an air intercooled setup with tons of pipe and its just not good, cant put a water heat exchanger setup easily on a OHV motor due to push rods etc in the valley... by the way if its a root blower thats not actually part of the main intake is it considered a positive displacement blower.. hmm I thinks not.
Old 01-10-2011, 11:13 PM   #5
Titus Wadicus
svtlx's Avatar
i seen a couple of s/c into stang transplants on youtube. definatley need a whole car to make it happen. but the guys on the supercoupe forums make good hp (300+rwhp). i was a mn12 tbird guy b4 i was a stanger. idk..i guesse unless someone is real commited, they should stay away from that sorta swap. it's pretty involved, and you do need a bit of intimate knowldge of the electronics.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-10-2011, 11:14 PM   #6
Titus Wadicus
svtlx's Avatar
also, tbird engine compartments are smaller than stangs..(i know, hard to believe)
Old 01-11-2011, 01:06 AM   #7
They need to come up with noisy timing gears for the v6 so we can have the wine but not have empty pockets.
Old 01-11-2011, 12:07 PM   #8
Titus Wadicus
svtlx's Avatar
im pretty sure a 302 set would work. they are kinda universal sets depending on the brand.
3.8 supercharger off a thunderbird??? 00stang3.8 Pre-2005 V6 Mustang 8 09-10-2007 10:57 PM
Thunderbird package? andreas Classic Mustangs 7 07-03-2007 08:22 PM
Thunderbird supercharger swap... crazeflier07 Pre-2005 V6 Mustang 10 05-04-2006 02:26 PM
No more Thunderbird 04MonteSS General Car Discussion 16 04-02-2005 08:23 AM
Thunderbird S/C swap veesix Pre-2005 V6 Mustang 10 09-22-2004 06:27 PM
11:46 AM
