Odometer comes and goes - Mustang Evolution
Old 01-06-2011, 03:19 PM   #1
I am tired of my odometer coming and going out on my 99 V-6, anyone know what causes this and how to fix it?
mightymav72 is offline   Reply With Quote
Old 01-06-2011, 03:29 PM   #2
Re: Odometer comes and goes
does it lose miles or just sometimes display and sometimes not?
Old 01-06-2011, 04:54 PM   #3
odometer and trip odometer function well, you can even reset it while it is out, it just blacks out from time to time.
Old 01-08-2011, 12:59 PM   #4
Loc: Austin,TX
May be a 99 issue my cobra did the exact same thing......so I sold it.
Old 01-09-2011, 09:08 AM   #5
Scrshaw's Avatar
My 01 V6 does that too, but it only happens rarely. I figured it was probably a loose connection somewhere going to the cluster. If I shut it off and back on again, the display comes right back. Then it will go months before it happens again. Since its only happened a few times, it seems like more trouble than it's worth to try and fix yet.
2001 Zinc Yellow V6 3.8L Coupe
65mm TB & Spacer, K&N FIPK CAI, Trac-loc, 4:10 Gears, Custom tune from Pro-Dyno, LT Headers, H-Pipe, High-flow Cats, Flowmaster 40's, UD pulley's, Upper and lower rear control arms, Drag launch springs, Line-locks, Custom Built 4R70W Trans,2500 RPM Torque Converter, Trans Cooler, 190 LPH fuel pump
Scrshaw is offline   Reply With Quote
Old 01-09-2011, 09:41 AM   #6
It may get worse, thats how mine started. You don't realize how important the odometer is for maintenance, mileage checks, etc, until you don't have it when you need it.
Old 01-09-2011, 12:38 PM   #7
Scrshaw's Avatar
Oh I hear ya and I do intend to fix it. I would just prefer not to do it in 20 degree weather if I don't have to! SInce it's only happend maybe 3 times since the first time it did it about a year ago, I figure I can wait till spring.
Odometer ? 99 SVT Cobra 1996-2004 Mustang GT 11 09-23-2010 08:22 PM
odometer 98mustang2007 Pre-2005 V6 Mustang 2 03-28-2008 04:14 PM
odometer not working 98mustang2007 1996-2004 Mustang GT 4 03-20-2008 10:25 AM
What to do when replacing Odometer? fast64 General Car Discussion 5 01-17-2008 08:52 AM
What does your Odometer read? DarkShadow General Car Discussion 54 06-18-2007 09:53 PM
10:58 AM
