Calling all Mustang 6 packers! - Mustang Evolution
Old 01-06-2011, 03:22 PM   #1
Ok, here's the situation: I have come into possession of a 1986 Mustang convertible with a 3.8 and a 3 speed automatic. I have an '83 Mustang with a 5.0 and a 5 speed for a toy. (what can I say...I likes the old ones!) I have a Jeep Wrangler, but it gets very little in the way of gas mileage. That's where this car comes in. What can I do to maximize the gas mileage? Mechanic wise, I can turn a wrench. I have most tools needed, but I haven't dealt much with fuel injection. I know the 3.8's from that era were notorious for blowing head gaskets and the fuel injection was barely adequate. I have an 8.8 axle with 2.73 gears. I have a T-5 tranny out of a T-Bird Turbo coupe, which has a steep first gear. That way, I get decent acceleration from the stop light and keep the highway gear. I have a bell housing, clutch assembly, divider plate and starter from a '94 Mustang 3.8. Now comes the hard part: What to do with the 3.8? Reliability is very important to me and I don't mind spending the $ to make it right. I was thinking about swapping out the 3.8 for a '99 or newer 3.8. Has anybody done this? I know I would have to use the wiring harness and computer out of the donor vehicle. How hard would this be? Or do you have any other engine suggestions? How about exhaust? I like the GT tailpipes for that year. I have heard that you want to keep the exhaust pipe to a 2 1/4 diameter. For gas mileage, which is the better header, long tube, short tube, factory or? All help is appreciated. Thanks!
kirbo7106 is offline   Reply With Quote
Old 01-06-2011, 03:31 PM   #2
Re: Calling all Mustang 6 packers!
94-98 vs 99-04 the fuel return systems differ~ thats one issue
Old 01-06-2011, 09:11 PM   #3
ponyboy94's Avatar
make sure you have full exhaust and n ot turn down because it will make you lose rear end down force and lose gas milage
ponyboy94 is offline   Reply With Quote
Old 01-10-2011, 11:05 PM   #4
Titus Wadicus
svtlx's Avatar
im not tryn to be a smartass, but how r turn downs goin to make a car lose downforce?
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-11-2011, 01:44 AM   #5
It won't.
But in the case of switching motors you can use your wire harness and ecm. You have to put all the sensors from your motor on the newer one and you will need either a smaller fuel pump"less pressure" or hook up a fuel return with an aftermarket fuel regulator. If you do not do this it will run rich as hell and possibly blow an injector or two.
I'm in the proscess of doing something like you want to do but its on a 92 taurus with a 3.8L. I've got a 01 mustang top end on it, and having trouble with it running rich but I don't have an adjustable fuel regulator on it and it has 70psi at the fuel rail contantly.
Straublittleman is offline   Reply With Quote
Calling all 6 bangers. DDTCM Pre-2005 V6 Mustang 84 06-09-2010 04:10 PM
Calling all Mustang owners DDTCM The Bar 2 11-30-2009 04:18 PM
calling ryan out! meteorachick The Bar 6 09-03-2006 08:55 AM
Calling Out Darkshadow!!!! Cajun JungleBoy Pictures and Videos 3 07-16-2006 10:11 PM
calling anyone and everyone out (v6 or gt) tire Pre-2005 V6 Mustang 8 04-18-2004 10:48 PM
09:35 AM
