vibration sensation - Mustang Evolution
Old 01-07-2011, 12:38 AM   #1
04V6ponyboy's Avatar
vibration sensation
When idling around 750 rpms my stand decides to vibrate and shake not like a stall but something else it all started when the new engine was put it. If I put the car in neutral it stops. Any suggestions its annoying
04V6ponyboy is offline   Reply With Quote
Old 01-07-2011, 07:35 AM   #2
Re: vibration sensation
you running the AC (I doubt it this time of year... but you are in FL). If so it could be that. My 01 v6 would idle rough below 700 rpms or so~ if you have a tuner you can modify the idle rpm and bump it up a tad.
You can clean the MAF sensor that helps control idle and the idle bypass valve. I assume its an auto as it would have more load in D while stopped vs N while stopped.
The MAF can be cleaned by using electronic on contact no residue cleaner (NOT brake fluid, can get at autozone), its kind of a pain to get to, why not do a cold air intake while you are dong it to kill two birds with one stone
Old 01-07-2011, 10:16 AM   #3
Rosco's Avatar
Why and how do you know everything about a mustang? Your like the mustang whisperer.
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 01-07-2011, 10:18 AM   #4
Yeah he replys on all my post he might be the mustang Jesus
Old 01-07-2011, 10:20 AM   #5
I wish I knew even 10% about them... the only reason I know a few tricks is because I screwed up in the past and had to ask or I found out by having the same issues lol
Old 01-07-2011, 12:17 PM   #6
stampde's Avatar
yup they actually make a MAF cleaner , you can get it at your local partsd store , DON'T USE carb cleaner !!!
2011 GT Auto
Old 01-07-2011, 01:01 PM   #7
Camo1967Mustang's Avatar
my baby used to do that too
it was cause her idle was too low
it helped that i had a tuner so i could just raise it a lil higher and now she is fine
Camo1967Mustang is offline   Reply With Quote
Old 01-07-2011, 01:29 PM   #8
Yeah I noticed that cause if I press the gas just a tiny bit and hold it its fine
Old 01-07-2011, 01:29 PM   #9
Or if I put it in neutral
Old 01-07-2011, 02:10 PM   #10
same here, there is always something new to learn with cars
it seems like when i think it could be something it could be something completely different
all cars are different and can be tempermental
i know my baby is, lol
Old 01-07-2011, 06:39 PM   #11
True story.
Old 01-10-2011, 10:42 PM   #12
Titus Wadicus
svtlx's Avatar
im think'n the idle is too low. the alternator stops charge'n at 650rpm. at that point the computer starts to do funny stuff, and the car can start run'n a bit rich cause the plugs aren't get'n enough juice...and the heater (heating element) for the mass air isnt get'n hot enough to give the computer a good measurement.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
? Wheel Vibration 08 GT skully 2005-2010 Mustang GT 14 10-27-2009 09:05 AM
vibration spw1001 1979-1995 Mustang GT 7 10-04-2008 01:21 PM
bad vibration dodgeman340 1979-1995 Mustang GT 8 03-19-2008 08:22 AM
Weird Vibration Jeremym831 1996-2004 Mustang GT 2 01-08-2008 07:32 AM
Sound Vibration megax29 Mustang Audio & Video 14 04-04-2006 09:21 PM
04:48 AM
