3.8 Heads - Mustang Evolution
Old 01-09-2011, 12:41 PM   #1
3.8 Heads
I know this is going to sound like a newbie question but...Are any of the production 3.8 heads better than the rest? Will a newer head bolt onto a 1986 block without any problems?
Thanks
kirbo7106 is offline   Reply With Quote
Old 01-09-2011, 07:12 PM   #2
Re: 3.8 Heads
You can bolt the heads on but 98-newer with split port you will need the intake and plenum and figure out the fuel setup since they only have one fuel line "no return line" fuel pressure is regulated in the tank. It would be a great upgrade both performance and reliability.
Straublittleman is offline   Reply With Quote
Old 01-10-2011, 09:48 AM   #3
Re: 3.8 Heads
you can send the heads off to have them ported and all that good stuff
Old 01-10-2011, 10:07 PM   #4
Titus Wadicus
svtlx's Avatar
Re: 3.8 Heads
+1...
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-28-2011, 03:28 PM   #5
NeedSomeMods's Avatar
Re: 3.8 Heads
Okay this is kind of an old thread, but, it's exactly the topic I was looking for.
If you don't know, I have two mustangs.
2000 mustang v6, auto.
1994 mustang v6, auto.
The 2000 threw a rod and needs a new motor.
The 1994 has a fresh transmission and I'm in the process of trying to restore/upgrade her.
I know the 2000 needs a new motor, but can I use some of the intake parts to go onto the 1994 model?
I know the 99-up have the split port induction system, while the previous models do not. Rather than getting rid of these parts, could I put them to use in the 1994?
NeedSomeMods is offline   Reply With Quote
Old 01-28-2011, 10:12 PM   #6
Re: 3.8 Heads
You would have to change the heads to split port and figure out a fuel return system or use a complete fuel sending unit out of a 98-04 mustang with one fuel line.
Heads upton7 Mustang Parts for Sale and Wanted 0 08-11-2009 10:51 PM
Which heads? upton7 1996-2004 Mustang GT 4 07-30-2009 11:14 PM
heads 05+ 4.0L V6 2007STANG Mustang Parts for Sale and Wanted 1 07-22-2009 12:02 AM
need help with heads johnnyc 1996-2004 Mustang GT 2 06-08-2009 01:15 AM
FS: BV Heads, 173's,Cam, and Stock Heads petrey10 Mustang Parts for Sale and Wanted 4 06-26-2006 11:15 PM
04:37 PM
