DIFF GEAR WHINE - Mustang Evolution
Old 01-09-2011, 11:41 PM   #1
DIFF GEAR WHINE
V6 vert, manual, motive gears, trac-loc, installed at 91,000. Took it back to correct a whine at 93,000. I am now at 96,200 little improvement. Should I take it back or did I already ruined the gears.
classman is offline   Reply With Quote
Old 01-10-2011, 09:46 AM   #2
Re: DIFF GEAR WHINE
once the gears wear the pattern its pretty much there... you will have to buy a new set. If the gears were used that could be why they whine, the next is they were not isntalled correctly, the final reason is they are richmond, motive, etc and those are known to be easier to whine based on their make up.
Most of the time its install, they didnt do it right.
Old 01-10-2011, 01:01 PM   #3
Re: DIFF GEAR WHINE
Will the whine get worse in time?
Old 01-10-2011, 01:16 PM   #4
Definitely would go with a new set. Those are pretty much ruined. I would reccomend a set from Ford Racing.
I rode in my buddy's car and his were so bad it was more like a howl than a whine. The sound will definitely not get better!
93CobraGuy is offline   Reply With Quote
Old 01-10-2011, 01:26 PM   #5
blackonblack's Avatar
Re: DIFF GEAR WHINE
they no longer make ford racing gears for v6. would have to get used. motive is 2nd to ford racing, but known for whine
2004 3.9L v6
Black on black on black
MAC Cold Air Intake, 4.10 gears + T-Lok, SCT Tuner, dual H piped flowmaster super 40's
blackonblack is offline   Reply With Quote
Old 01-10-2011, 04:27 PM   #6
Titus Wadicus
svtlx's Avatar
Re: DIFF GEAR WHINE
lmao...my ram whines like a city bus.. my gf's dad thought he was in a semi (he drives one). mine didnt get worse, but i cant afford to have the truck down again cause it's my work truck. however, got 2 mtx 10's and 8 other speakers in the truck...so i just turn up the stereo and live with it. im tired of arguing wit the installer.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-10-2011, 05:42 PM   #7
Re: DIFF GEAR WHINE
When did they stop making gears for a 7.5?? Thats going to hurt allot of people since 99% of the rear wheel drive cars have that rearend.
Straublittleman is offline   Reply With Quote
Old 01-10-2011, 08:03 PM   #8
I have motive and no whine
Old 01-11-2011, 10:31 AM   #9
Re: DIFF GEAR WHINE
i also have motive and no whine.. still known for whine
im not sure when they stop making ford racing gear for 7.5, but i was told that several times in my search for gears
2004 3.9L v6
Old 01-11-2011, 11:44 AM   #10
Re: DIFF GEAR WHINE
see if the shop will do something about it or if they try to give you the run around and blame it on something stupid~
Old 01-11-2011, 12:26 PM   #11
Titus Wadicus
svtlx's Avatar
Re: DIFF GEAR WHINE
lmao!! the guy at the shop told me it was a ground noise i was hearing from all the emergency equipment in my truck. i told him i been in cruisers since 95..that's a different noise. comes through the speakers. it's the gears, not my l.e.d.'s.. blaming it on something super stupid...wtf
upgraded gears and a diff. whine classman Pre-2005 V6 Mustang 5 06-18-2010 12:01 AM
engine whine? tedness Pre-2005 V6 Mustang 34 05-02-2005 09:28 PM
auto/manual tranny gear and rear gear STOCK ratios SpectorV Pre-2005 V6 Mustang 0 07-08-2004 02:41 PM
Engine whine DropTop_Stang Pre-2005 V6 Mustang 33 12-29-2003 02:22 AM
10:36 PM
