95 mustang problems - Mustang Evolution
Old 01-11-2011, 10:43 AM   #1
Region: Iowa
95 mustang problems
Hey I'm new to this forum but it seems like a pretty cool place. Anyway I have a 95 stang and iv change the thermostat, water pump, and power steering pump on this thing. The problem I'm running into is the heat gauge keeps pegging out on me. Iv dropped the fluids out of it like 3 times and bled the thermostat like iv been told to do and it still overheats. Anyone else ever have this problem??
Zach
Zachinnis is offline   Reply With Quote
Old 01-11-2011, 11:18 AM   #2
stampde's Avatar
Re: 95 mustang problems
maybe its a bad sensor / is it over heating ?
2011 GT Auto
Old 01-11-2011, 11:21 AM   #3
Region: Iowa
Yes. I let it run for a bit and it just pegs out
Old 01-11-2011, 11:41 AM   #4
hmm do you hear the T-Stat open and fluid pump? Sounds like its got air in the system if the t-stat is opening up etc.
you can get ford to vacuum the system and let fluid get sucked back in~
the stock gauge on temp works in your year actually if I remember right, but its not super accurate. You can use another gauge to double check the real temp to make sure its not just a bad sensor.
Old 01-11-2011, 11:48 AM   #5
Region: Iowa
Actually I don't. And the hoses going in are cold. And the ones out are scalding hot
Old 01-11-2011, 02:10 PM   #6
Thegabrielles's Avatar
Open up the radiator cap and see if the antifreeze if flowing, mkae sure and open it when its cold, then wait until it gets to operating temp and see if it is "flowing" through the radiator. Seems to me that you may still have a bad thermostat. I think it would be fairly simple to diagnose in person, pain in the neck on here.
If the hoses coming out are hot and the ones going in are cold your antifreeze is not flowing. Another possibility is the wrong water pump! I cant remember what years they changed directions, seems like it was back in the 80's but if you got the wrong one it would definitely be a problem. Maybe someone else can chime in, been a long time since I worked on the 80's, 90's models.
2011 Roush Stage 2 Convertible Race Red with black stripes, Charcoal Interior
Roush # 11-0306,Roush Front and Rear Brake Kit, Roush Exhaust with Square tips, 20" wheels with Cooper Tires Roush Billet Grille matching lower 3 piece, Matte Black side and top stripes, White Face Gauge cluster, Convertible Light Bar
Purchased 27Dec2010
Thegabrielles is offline   Reply With Quote
Old 01-11-2011, 09:37 PM   #7
Region: Iowa
It's all the way to the top next to the cap :/ my guess is that it needs flushed. I was hoping that I wouldn't have to do that.
Old 01-11-2011, 09:53 PM   #8
Its at teh top, but is it moving? You need to remove the cap, start it u and wait to see if the antifreeze is flowing through the radiator. Flushing may be necessary, but if its not flowing something else needs to be done first.
Purchased 27Dec2010
Old 01-11-2011, 09:57 PM   #9
Region: Iowa
It comes flyin out when the cap is removed haha. When u press on the accelerator it goes back down though.
65 mustang problems Dmay65 Classic Mustangs 0 01-03-2011 06:49 PM
02 Mustang Possible Transmission Problems TK225 General Mustang Discussion 3 10-07-2008 06:41 AM
Problems with 1991 Mustang GT wmsoccer28 1979-1995 Mustang GT 10 08-20-2007 09:48 PM
mustang problems?? MarcyWK Pre-2005 V6 Mustang 7 05-08-2006 12:54 PM
What problems have you had with your mustang? mstnglvr The Bar 20 07-09-2004 10:02 AM
07:25 PM
