stall and exhaust ? - Mustang Evolution
Old 01-11-2011, 12:48 PM   #1
stall and exhaust ?
well just wanted to know if there was a big diference in a gt stall than my 00 v6 stall i want to put one on just love the sound of a stall but nothin to big so will it make a difference or not if not do uall know where i can get one and of to the second ? at the moment i have shorties with glasspaks to an xpipe and dual side exit exhaust just wanted to know should i change my exhaust or just leave it the way it is thanks guys
3.8boii is offline   Reply With Quote
Old 01-11-2011, 12:54 PM   #2
Re: stall and exhaust ?
what do you mean by stall, like a stall converter for an auto?
Old 01-11-2011, 01:42 PM   #3
yup
Old 01-11-2011, 02:18 PM   #4
How is a stall supposed to change the sound of your car? I would do gears and the rest of the boltons first. You should be able to stall yours up to about 1800 before the tires break loose. I wouldn't recommend much more than a 2500-3000 for a dd especially since we don't have the power anyway. And I love my exhaust and personally believe its the best option for sound
tigerfan2771 is offline   Reply With Quote
Old 01-11-2011, 08:49 PM   #5
Titus Wadicus
svtlx's Avatar
+1
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
exhaust
Stall converter 90blue5.0gt 1979-1995 Mustang GT 31 01-12-2011 07:09 PM
What programmer/stall? 01 PR RAGTOP 1996-2004 Mustang GT 3 07-18-2008 11:15 AM
stall converter???? stang_gang Classic Mustangs 6 05-01-2008 05:18 AM
stall converter Kyle Pre-2005 V6 Mustang 5 12-15-2006 05:50 PM
300 stall? midnightmustang Pre-2005 V6 Mustang 9 05-16-2005 10:12 PM
01:58 AM
