turbo/supercharger - Mustang Evolution
Old 01-12-2011, 08:20 PM   #1
ponyboy94's Avatar
turbo/supercharger
hey guys im looking for a turbo or a super charger for my 02 v6 i was wondering where to get one cheap or if anyone is selling one cheap
ponyboy94 is offline   Reply With Quote
Old 01-12-2011, 08:27 PM   #2
Dont get one. Its not worth it for a v6. Buy a v8 and of u still need more power get a vortech for that.
sno4life is offline   Reply With Quote
Old 01-12-2011, 08:39 PM   #3
ponyboy94's Avatar
Re: turbo/supercharger
but i mean if its cheap enough why not
Old 01-12-2011, 08:41 PM   #4
I agree. Not worth it for a v6. I have a 2000 bored to 308 vortech V1 superchaged stang. Too much power. Keep in mind mpg will suck
Dnraiders is offline   Reply With Quote
Old 01-12-2011, 08:56 PM   #5
Ur not gonna find one cheap enough.
Old 01-12-2011, 09:01 PM   #6
MC770's Avatar
Your best bet is to get an eBay turbo for your engine size and have a shop or if your skilled enough make the tubing and lines for it....
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 01-12-2011, 09:03 PM   #7
Which will end up being about 2,000 if ur lucky...
Old 01-12-2011, 09:05 PM   #8
MC770's Avatar
For the turbo itself, no
But if you had a shop install it, it wouldn't be that cheap but probably cheaper than buying a kit...
Old 01-12-2011, 09:07 PM   #9
I was saying the combo. As in the price to buy it plus the price to install it.
Old 01-12-2011, 09:15 PM   #10
MC770's Avatar
But installing it your self would save you cash there. And most of the eBay turbos are 200 or just under 200.
Old 01-13-2011, 08:29 AM   #11
Mustangguy0202's Avatar
Keep an eye out on eBay and craigslist.. I got my $5,000 STS turbo kit on craigslist for $700 I just couldn't resist a deal like that lol and did the install myself... And to those that say it isn't worth it I'd have to disagree there's no feeling like that of beating a V8 with a V6 and to see the look on their face after it happens lol it never gets old
Mustangguy0202 is offline   Reply With Quote
Old 01-13-2011, 09:17 AM   #12
drusmith's Avatar
Send a message via Yahoo to drusmith
Buy a Terminator!!!! they come with a SC. I will never see a V6 beat me that is for sure!
But if you want more HP for your V6, turbo is the way to go! Much more efficient for what you want! And you can find them on ebay for cheap. Just make sure you have all the supporting mods as well. I know the feeling of a V6 beating a V8. I do it every day with my daily driver. 300frhp SSEI! Its fun, let me tell ya!
Try this: Cheap! Just make sure you have someone or yourself do it RIGHT!!!!!
STAGE 2 T3/T4 TURBO KIT MUSTANG V6 V8 3.8L 4.8L 5.0L GT - eBay (item 330458394866 end time Feb-01-11 19:50:42 PST)
drusmith is offline   Reply With Quote
Old 01-13-2011, 10:45 AM   #13
My daily driver as well 08 V6 mustang with STS turbo, intercooler, 42# injectors, predator MAFia sensor, bbk headers, 3.73 gears, T-lok, bbk throttle body and spacer... And I'm sure I'm forgetting something but 350+ hp at the wheels
Old 01-13-2011, 12:21 PM   #14
Titus Wadicus
svtlx's Avatar
and wut kinda gas milage u see with that thing. 42#ers, its gotta be dropn fuel in by the shot glass
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-13-2011, 12:24 PM   #15
I get about 280 miles per tank so no as bad as u would think... It's the gears that really hurt it
Old 01-13-2011, 12:31 PM   #16
tma used to make turbos for the 3.8L and was supposed to start back up again, they are like 4k~ or so and on 10psi should be 350rwhp or so on a manual trans, superchargers are out there as well but wont push nearly as much, about 280rwhp on 10psi.
Old 01-13-2011, 12:31 PM   #17
if your not in the boost your gas mileage should be about what it would be N/A... mine is somewhere between 24mpg and 3mpg depending on how much throttle I use
Old 01-13-2011, 12:32 PM   #18
Titus Wadicus
svtlx's Avatar
how many pounds are you runnig? my cam is at .529 lift w/8cyl @11lbs. i tried 42's and it was so incredibly rich...practicaly flooded my cylinders...pure white smoke and raw fuel. wut size are your cumbustion chambers?
Old 01-13-2011, 12:38 PM   #19
Titus Wadicus
svtlx's Avatar
lmao... im start'n to wonder if i should bump my timing up abit. ive kept it at 10 degrees advance which is pretty low. maybe if i bump up to 12 or 14 i would see a mpg gain. every since i put the blower on ive left it at ten.
Old 01-13-2011, 12:42 PM   #20
Stock combustion chambers but I'm only running 7psi with a good tune and yes had to adjust the air to fuel ratio
Old 01-13-2011, 12:44 PM   #21
Yea exactly which is y the gears hurt more than the turbo
Old 01-13-2011, 12:53 PM   #22
Titus Wadicus
svtlx's Avatar
that just seems like an awful lot of injector for only 7lbs. and ima assume 69cc combustion chambers. that's sum serious work for the injectors to have have them work that kinda duty cycle out of optimum range. seems like u would wear the springs out soon. and possibly hurt ur milage a tiny bit having them cut their duty cycle in probably half.. idk...im just thinkn out loud. i love to see other ppl's set-ups. wut kinda hp r u pushn at the wheels, u know yet? sounds like a wild ride u got there.
Old 01-13-2011, 01:21 PM   #23
Don't have an exact number but I know it's over 350 at the wheels easy probably around 375 or so
Old 01-13-2011, 01:25 PM   #24
Titus Wadicus
svtlx's Avatar
not bad...i could c u walkn all over a few gt's and camaros
Old 01-13-2011, 02:55 PM   #25
Well, if the OP is interested, I've still got my M112 setup I need to get rid of.
19Delta is offline   Reply With Quote
Old 01-14-2011, 09:40 PM   #26
Las0mbra's Avatar
How much man?
Old 01-14-2011, 10:26 PM   #27
I'd take 1000 for everything.
Old 01-14-2011, 10:42 PM   #28
Las0mbra's Avatar
Dang, that's a good deal... Too bad my car has 95k on it now and I would probably end up on the side of the highway picking up bits of my engine.
Old 01-14-2011, 10:44 PM   #29
ah, if you don't push it past 6-8psi you shouldn't be too bad off. You can always hit up SSM and get a piece at a time to beef your engine up.
Old 01-14-2011, 10:46 PM   #30
Titus Wadicus
svtlx's Avatar
dats not gonna happen wit 95k..
Old 01-14-2011, 10:47 PM   #31
Yeah no joke, mine has almost 150k on it. Just make sure you do the regular maintenance and replace everything before you start, haha.
Old 01-14-2011, 11:06 PM   #32
Las0mbra's Avatar
True... But with the way I drive...
Old 01-14-2011, 11:16 PM   #33
Titus Wadicus
svtlx's Avatar
if you drive like that, then you will blow a fresh motor wit 5k on the clock...that's real talk. so u might as well
Old 01-14-2011, 11:17 PM   #34
Las0mbra's Avatar
Haha, yeah.
Old 01-14-2011, 11:18 PM   #35
Well, the parts aren't going anywhere, they've been laying in my floor in my spare bedroom for almost a year, just haven't had the time nor extra cash to get it put on and tuned.
Turbo vs Supercharger chrisinbeav Pre-2005 V6 Mustang 15 09-15-2008 11:57 AM
04 v6 looking for supercharger or turbo maxwelmurder Pre-2005 V6 Mustang 24 09-01-2008 03:24 AM
Supercharger or turbo? DonnyM32 Pre-2005 V6 Mustang 10 07-23-2006 10:29 PM
turbo or supercharger fastang11 Pre-2005 V6 Mustang 24 01-02-2006 09:36 PM
turbo or supercharger TexaStang Pre-2005 V6 Mustang 6 07-20-2005 09:26 PM
05:33 AM
