Axle gear set up for 7.5? - Mustang Evolution
Old 01-13-2011, 04:58 PM   #1
Can anyone provide me with the set up method for a new set of axle gears and spider gears for a 7.5 rear differential?
jsmith is offline   Reply With Quote
Old 01-13-2011, 05:41 PM   #2
Re: Axle gear set up for 7.5?
as far as installing you need to get a professional to do it as if they are not shimmed correctly, backlashed correctly, have their pattern tested correctly, as well as many other things they will whine, they will wear a bad pattern, and they will have to be redone correctly costing you another set of new gears and repeating the process.
installation is generally 200+ depending on shop, gears are around 200, and a tlok unit (dont install the open diff one wheel peal unit upgrade to a tlok or auburn diff for the 7.5) is 150+ depending on which way you go.
Finally, just because a shop says they know what they are doing does not mean they do... dont trust race car drivers that dont street drive their car, you wont hear a whine with a super loud car going 0-100 and thats it lol. Try to get a warranty on whine noise etc and shop around.
shifting into gear, axle noise audio75 Pre-2005 V6 Mustang 9 07-18-2010 11:08 PM
t-lok and gear set change 02V6TTcoupe Pre-2005 V6 Mustang 2 12-13-2006 02:45 PM
Gear and axle swap questions. DarkShadow Pre-2005 V6 Mustang 15 09-07-2005 02:18 AM
auto/manual tranny gear and rear gear STOCK ratios SpectorV Pre-2005 V6 Mustang 0 07-08-2004 02:41 PM
gear set starboarder2004 Pre-2005 V6 Mustang 5 01-13-2004 08:03 PM
04:27 AM
