engine swap from v6 to 306 - Mustang Evolution
Old 01-13-2011, 09:11 PM   #1
sup guys. i got a few dollars on me and i want to get a new and improved powerful engine for my 2005 v6 stang. i was wondering if i swap my v6 engine with a 306 crate engine. would i have to get another transmission? i sure hope i wouldnt have to get a rear end or something. im not a mechanic so hoping someone could help me out with this. and if i would have to get a new tranny. could i get the tci tranny or what? need help. highly appreciate it. thanks guys.
ballen666stang is offline   Reply With Quote
Old 01-13-2011, 10:36 PM   #2
Titus Wadicus
svtlx's Avatar
Re: engine swap from v6 to 306
if it's a stick u may have to change bellhousing..dont quote me on that. if you go auto, i would suggest a racing aod. you will get consistant shifts as well as cut down on the electronics needed to run an electric unit. as far as the rear end, you do wutever u want or just leave it alone, but chances are you will wanna upgrade to a higher gear ratio. also, u dint say if you were goin carb or efi with the 306.
last but not least, not to deter you. but your talkn bout a pretty finacialy intensive project if your not doin the work yourself. you mentioned you werent a mechanic. it may be cheaper for you to purchase a factory v8 car. the project you wanna do isnt rocket science, but v-6 to v8 swaps are far from novice level ...especialy if you plan to go fuel injection. however, if your adventurous and have aome spare time, knowledgable friends, and sum patience....but all means jump on it. you will learn tons by the time it's up and running.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
engine swap 1989 to 1992 4 cyl engine dannyc1992 General Mustang Discussion 0 02-08-2008 01:59 PM
Help with a 306 build Jay Rod 5.0 1979-1995 Mustang GT 7 04-20-2007 05:32 AM
Want to swap my v6 engine for a v8 Justin-Heath Pre-2005 V6 Mustang 10 12-08-2006 03:56 PM
Engine Swap/ Engine Shakes too_cool_mitch Pre-2005 V6 Mustang 2 02-28-2006 02:01 PM
engine swap evilweirdo42 Pre-2005 V6 Mustang 26 11-23-2004 07:21 PM
02:09 AM
