Mustang Forum
Go Back   Mustang Evolution > Mustang Forums > V6 Mustang
Thread Tools
Old 07-14-2007, 11:29 AM   #1
split port swap question
ok i just bought the stuff needed for a split port swap in my car.. well i think its everything n i was just wonderin if u could double check for me n see if there is anything else i need..
Heads
Upper intake
Lower intake
Upper and lower radiator hoses.
Coils and plug wires
Heater hoses
Coolant bypass tube
Thermostat housing (attached to the lower intake)
Upper engine gasket kit.
EGR valve and tube
TPS sensor and throttle body
throttle cable and bracket
intake tube
IAC
Fuel Rail - ** Not modified**
i dont remember if i read right but a while back i thought i seen somethin about i need to get bigger fuel injectors too.. eh im just wonderin..
immenukka is offline
Old 07-14-2007, 12:34 PM   #2
Re: split port swap question
http://www.supersixmotorsports.com/p...GarageSale.pdf
$800 from Super Six Motorsports. Includes the modified fuel rail. You can run the EV1 fuel injectors from your engine now, but I believe that they will be close to maxed out.
Most people go ahead and swap to the EV6 fuel injectors while they are doing this.
matthews.stang is offline
Old 07-14-2007, 02:09 PM   #3
I don't think the egr will bolt up directly. The headers on your gen are a little different than the split ports.
You may have to delete it. And I would definiltey goto 19lb injectors.
Kiljosh is offline
Old 07-14-2007, 08:16 PM   #4
I think you have to bend the pipe a little more.
I "believe" they went from a header ('94-'98) to a manifold ('99-'04).
Old 07-14-2007, 09:27 PM   #5
nooo dude the stuff that i have listed is everything that i already have.. lol it was pulled off of a 2000 v6.. im tryin to get them ported and polished before i put em on but money is tight and i cant find anywhere to take them to get that done.. sooo yea.. lol where is a good place to get the fuel injectors?
Old 07-16-2007, 11:37 AM   #6
I found a nice set of used 19lbers on ebay.
Although, that is hit or miss when it comes to injectors. I dont buy used pats anymore...
Kiljosh is offline
Old 07-16-2007, 11:54 AM   #7
you can find used ones for cheap im sure, i dont see a maf on your list, you have to have the new one thats set for 19lb injectors
SpectorV is offline
Old 07-16-2007, 12:07 PM   #8
your single port harness may have to be lengthen to reach the coil packs and EGR .The coil packs are the same 94-2000 If you have 01-04 parts, you can fab up a bracket to mount to the intake Your gonna need the modified fuel rail
Herbstang is offline
Old 07-16-2007, 06:28 PM   #9
oh sorry i must have left the maf out but i did get that too.. sooo since i got that, thats means i am gonna have to have 19lb? or what sorry fo the dumb questions im just a little confused.. but here is the link that shows everything i got
eBay Motors: 94-98 Mustang 3.8 V6 Split Port Swap Complete take off (item 290135496178 end time Jul-09-07 20:51:21 PDT)
but yea where could i get some 19 lbers? and would autozone be a good place? and also whats a good brand of injectors to buy?
Old 07-16-2007, 06:39 PM   #10
You can use the injectors you have now, but they will be maxed out.
Old 07-16-2007, 06:53 PM   #11
ok cool.. see im gonna change em i wanted to just wait like a pay check or 2 so i can build my money back up for more mods.. lol but yea the injectors i have atm should be good for a lil bit right? n what do u mean by maxed out?
Old 07-17-2007, 04:10 AM   #12
To put it simple, the injectors you have are good for 150hp +/-. You will be making 190hp. So there is a chance that a cylinder may not get enough fuel all the time.
Old 07-17-2007, 08:59 AM   #13
the injectors will be very cheap to pick up used
SpectorV is offline
Old 07-17-2007, 09:06 AM   #14
but arent the 99 up runnin the same size injectors? thats what i always had thought and do u think that it would just be better to get like 24.. just cuz im doin more mods not sure what yet but i am haha
and where would be the best place to get some of these injectors? off ebay or what?
Old 07-17-2007, 09:15 AM   #15
No i believe 94-98 are 14# and 99-04 are 19# and u can use the stock MAF but you are going to have to get a tune for the larger injectors esp if you are doing more than just the split port swap
rydog is offline
Old 07-17-2007, 09:29 AM   #16
what exactly do u think about these..
Mustang 3.8L V6 Performance Parts FREE SHIPPING!
are they a good price or what? i mean would they be a good option for my car? oh and whats the difference between ev1 n ev6?
Old 07-17-2007, 10:43 AM   #17
First off, don't order from them. There have been several horror stories from RPM Outlet on other message boards.
EV1 is what you have now. They are the 'old' style. EV6 is the 'pencil-tip' style. For the EV6, you will have to rewire the pigtail adapters.
Old 07-17-2007, 10:52 AM   #18
What he said !!
Old 07-17-2007, 10:14 PM   #19
mmk i see.. haha thanks for the advice on rpm.. so wait.. i got the fuel rail for a 2000.. which one r for that fuel rail?
Old 07-18-2007, 07:26 AM   #20
That is a returnless fuel rail you have a return style fuel system so it will not work without modification and both injectors will work with that fuel rail it is the fuel injector plugs that will not work with the pencil style injectors ie. 99-04
rydog is offline
Old 07-18-2007, 08:36 AM   #21
grrr and how exactly would i modify the rail to be able to hook up with these injectors?
Old 07-18-2007, 10:53 AM   #22
check with Jason at VMP He was selling the modify fuel rail like the one in the pic i posted or Modified your fuel rail with a universal fuel pressure regulator, and a return line
The way the fuel rail is done is the regulator and return line section are cut off of the single port rail, and then married into the front of the split port rail.
The 99 Mustang has a returnless fuel system. That means that the EEC controls the flow rate of the
fuel pump directly and all the fuel that is sent to the engine is used. In 94-98 cars, fuel is sent via the
fuel pump at a predetermined flow rate to the fuel rails and the fuel pressure regulator (using manifold
vaccuum to determine fuel needs) returns all the fuel that is not necessary back to the fuel tank.
Also the injectors are not equally spaced out on the 94-98 cars but they are in the 99's. So you cannot
use your 94-98 fuel rails as is. And you can't use the 99 fuel rails as is because there is no FPR (fuel
pressure regulator) nor return rail.
The easiest method to get around this problem is to modify the 99
fuel rails. You will probably want till cut into the rear of the 99 fuel rail setup and cut at the same
place on your set of 94-98 fuel rails and keep the return rail (that runs on the passenger side intact).
Then toss the back end of the 99 rails in favor of the back end of the 94-98 rails (with return rail)
since this include the FPR. You will need to weld the two different rails together at both cuts. The new
return rail should be able to work with its entire length (from FPR to the rubber return hose) intact.
You will need to either tig or spot weld the 94-98 return rail (loose except at connection with FPR)
to the '99 passenger side rail (which is fixed in position due to the passenger side injectors).
Now you have working fuel rails. The '99 rails will accept their new 19 # injectors and plug into the
'99 heads.
Old 07-18-2007, 08:24 PM   #23
ok soo... will someone help me out n help me try n find some good priced injectors new or used.. idc im just really confused haha.. i looked off ebay and like they all come in a set of 8 so does that mean they are only for v8s? but yea.. can someone please help a 18yr old out haha
Old 07-19-2007, 10:43 PM   #24
ok ok ok but there is still something that im extremely comfused about.. there is like sets of 8 fuel injectors.. and i cant find any sets of 6 for my car.. n basically what im askin is will all injectors fit on my fuel rail? like v8 and v6.. because im confused about what will go on the fuel rail.. do all injectors fit on both v8 and v6 is what im askin
Old 07-21-2007, 12:36 PM   #25
I believe that they are all the same.
I've heard of split ports that have boost are running '03 Cobra injectors.
Old 07-23-2007, 09:30 AM   #26
94-98 injectors are shorter and use a different plug, 99-04 injectors are longer and will fit your fuel rail but you will have to drill out were it bolts to the intake because the injectors are longer, so yes all injectors will fit your fuel rail but 99and up are longer and have different plugs hope that clears it up
rydog is offline
Thread Tools
Split port swap questions big show 98 V6 Mustang 13 01-09-2010 02:27 PM
split port swap fuel rail immenukka V6 Mustang 4 08-09-2007 10:40 PM
split port swap rydog V6 Mustang 4 07-25-2007 12:07 PM
single port to split port conversion NorwegianMustang V6 Mustang 3 06-19-2006 03:19 PM
Split-port swap post? Kiljosh V6 Mustang 6 11-15-2004 03:40 PM
» Advertisement
» Mustang Evolution Facebook Fans
» Garage of the Month
Featured Mustang
Brooke
jimmy_beaner
01:41 AM
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.1 PL1
Vendor Tools vBulletin Plugins by Drive Thru Online, Inc.
