motor swap - Mustang Evolution
Old 01-14-2011, 06:59 PM   #1
motor swap
Does anyone know how hard it would be to swap a 98 v6 mustang automatic to a 98 cobra motor 5 speed. Have a complete dokie car with all the parts.
98bluestang is offline   Reply With Quote
Old 01-14-2011, 09:17 PM   #2
Titus Wadicus
svtlx's Avatar
Re: motor swap
it would seem after you swap the k-member and wiring harness the rest would be pretty straight forward..and rear end.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-14-2011, 10:30 PM   #3
Re: motor swap
You're better off just buying a v8.
19Delta is offline   Reply With Quote
Old 01-15-2011, 07:07 AM   #4
Region: Iowa
Ya the nice thing I figured out with these cars is that v8s fit next to perfect on them. Switch the rear end and drill new holes for mounts and it practically done
Zachinnis is offline   Reply With Quote
Old 01-15-2011, 10:57 AM   #5
Ok good what about on the inside will I need to do anything to the interior besides just get the console
Old 01-15-2011, 10:58 AM   #6
Region: Iowa
Not that I'm aware of. The only problems iv ever heard of was that u might have to carve out some more room for the tranny
Old 01-15-2011, 12:27 PM   #7
Titus Wadicus
svtlx's Avatar
Re: motor swap
carve out room for the tranny? the bodies are the same between the two cars. im getn ready to do a 97 right now. and im not sure bout drilln holes for motor mounts..its not a chevy. he should just swap out the kmember if he has both cars. it's just a swap...no drill'n is necessary on anything. like a plug and play stereo swap.
Old 01-15-2011, 12:47 PM   #8
New
Re: motor swap
hey im trying to do a swap on a 01 v6-v8. I really want to put in a crate motor instead of the standard 4.6. does anybody know the process? n where could i find a gt for low price to do the swap?
New is offline   Reply With Quote
Old 01-15-2011, 11:07 PM   #9
Re: motor swap
No need to change K-member. You will need engine, trans, wiring harness, radiator, all hoses and lines, instrument cluster, driveshaft, rear end and I would recommend doing suspension and brakes at the same time as well.
Old 01-16-2011, 01:26 AM   #10
1ijack's Avatar
Send a message via Yahoo to 1ijack
Re: motor swap
Dont forget you will need to computer out of the cobra and needs to be installed.
The Mustang Mafia
"Join the family, if you dare"
www.themustangmafia.com
1ijack is offline   Reply With Quote
Old 01-17-2011, 11:08 AM   #11
Titus Wadicus
svtlx's Avatar
Re: motor swap
so ur sayn 01 v6 uses the same mounts as a modular v8? i know 3.8 and 5.0 use the same mounts...but modular uses differnt. is 01v6 a modular configuration? i thought he was swapn a 3.8 based v-6 to a modular v8...which use different mounts, so he would have to swap in the v8 cobra k member...
do i have an incorrect understanding?
motor swap v6 to v8 El Jefe Pre-2005 V6 Mustang 5 12-23-2009 09:06 AM
2003 3.8 swap 2001 4.6 motor mustang0386 Pre-2005 V6 Mustang 3 06-16-2009 10:18 AM
Motor Swap Help IbleedBlue General Mustang Discussion 2 03-12-2008 06:18 PM
Motor Swap coolstang 1996-2004 Mustang GT 1 04-20-2005 09:04 PM
Motor swap question. ShwoffGT 1996-2004 Mustang GT 32 02-21-2005 09:57 AM
09:30 PM
