hello - Mustang Evolution
Old 01-15-2011, 08:43 AM   #1
hello
i just bought a 97 v6 mustang, it has 180xxx klicks so its not to much for the year, i only payed 2500 for it and there isnt 1 thing wrong its in mint shape, it currently has a cold air intake, under drave pulleys, custom leather seats, and billet take offs from a new mustang, true dual exhaust also. i just bought a super charger kit for it, it was used but not very much use, its an eaton and i also picked up one of the volo chips and 30lb injectors, i got a bost, volt and air to fuel gauges and the pillar also, i have built alkind of sound systems, my last was 1 15" rockford fosgate in ported box and 3 10" RE audios, it was nuts but weight alot so i just thought id rip all that out and build a new one, i only going to use 3 10"s so ill keep everyone updated but away from all of that, i was just wondering if i will need anything else to put my super charger on and what are some good things i could do to the car aside from all that, just let me know like anything from the motor to the interior to exterior..thanks
ID:	22812   Click image for larger version
ID:	22814   Click image for larger version
chris purcell is offline   Reply With Quote
Old 01-15-2011, 08:51 AM   #2
Re: hello
heres more pictures
ID:	22817   Click image for larger version
ID:	22819   Click image for larger version
Old 01-15-2011, 08:56 AM   #3
06mustangmike's Avatar
Re: hello
nice ride,welcome:}
06mustangmike is offline   Reply With Quote
Old 01-15-2011, 09:11 AM   #4
Welcome the forum!
sno4life is offline   Reply With Quote
Old 01-15-2011, 09:12 AM   #5
Re: hello
thanks
Old 01-15-2011, 09:13 AM   #6
Re: hello
i also hear the 30lb injector are ****ty, anyone know why and what the solution would be and what size it should have
Old 01-15-2011, 10:16 AM   #7
Camo1967Mustang's Avatar
Re: hello
nice stang
Camo1967Mustang is offline   Reply With Quote
Old 01-15-2011, 10:57 AM   #8
MC770's Avatar
Re: hello
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 01-15-2011, 12:58 PM   #9
Re: hello
anyone have any ideas??? help
Old 01-15-2011, 03:55 PM   #10
Titus Wadicus
svtlx's Avatar
Re: hello
you may wanna add an adjustable fuel pressure reg. but i dont see 30lbs injectors holding you up with a stock 3.8. even if you added 2-3 more psi with a pulley, 30lbs injectors are fine. maybe bump the fuel pressure up (maybe). im not a 3.8 expert, but i make good power with supercoupe injectors. nice car btw, and good luck wit your blower install.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-15-2011, 03:59 PM   #11
Re: hello
thanks for the help
Old 01-15-2011, 09:25 PM   #12
Nasty Bite's Avatar
Nice, welcome!
Nasty Bite is offline   Reply With Quote
Old 01-15-2011, 09:52 PM   #13
1ijack's Avatar
Send a message via Yahoo to 1ijack
Re: hello
Nice Ride and welcome to the forum
The Mustang Mafia
"Join the family, if you dare"
www.themustangmafia.com
1ijack is offline   Reply With Quote
Old 01-17-2011, 07:53 PM   #14
Re: hello
Beautiful car to start out with. Congratulations. Have fun with it, drive safely.
Old 01-18-2011, 07:34 AM   #15
Qwik Four Six's Avatar
Welcome. Nice car. Reminds me of my 97. It had 171,000 on it and a bbk cai, h pipe catted with flowmaster super 44s, lowered, clear turn signal markers and 17" bullits. Honestly, send me a message if you decide to sell this one. I would deffinitely buy it.
Qwik Four Six is offline   Reply With Quote
Old 01-18-2011, 07:36 AM   #16
This is my old one.
Old 01-18-2011, 08:40 AM   #17
Welcome! Nice ride!
Old 01-18-2011, 12:42 PM   #18
Re: hello
thank you all, mine is idenical to yours blb97stang, anybuddy know what i should do next and what kind of ehaust is the best to go with, i have a true dual system now but i want the deep rumble like ive seen with the flow master 40s, if you know send some links with some that you know are good an have ordered stuff from before so i know it will be good durring the shipping process. id apreciate it
Old 01-18-2011, 12:59 PM   #19
Re: hello
Flowmaster 17112 Exhaust System Ford Mustang 1994-1997 on eBay.ca (item 300512682235 end time 06-Feb-11 17:32:41 EST)
this is another system i found
Old 01-18-2011, 02:50 PM   #20
This is my old 1996 mustang v6 with true duals, 3 inch chrome tips, and flowmaster 40 series.
Old 01-18-2011, 02:51 PM   #21
This is my old 1997 mustang v6 with a catted H pipe, 2.5 piping, 2.5 tips, and flowmaster super 44s.
Old 01-18-2011, 03:20 PM   #22
Re: hello
i know my v6 will never be anything like 900hp but thats the type of sound i wanted, mine already sounds like the flowmasters and all them, its pretty much the same thing, theres no really much point because mines brand new it self, i dont know if you seen this one on ebay or not its called pypes true dual exhaust, thats the pipe i have so i dont really need one but i dont really have anything left to do to the car and i really like the rumble when its idleing on that car in the video i linked, if you have any suggestions on what i should do to my car besides the things i have let me know thanks
Old 01-18-2011, 03:20 PM   #23
Re: hello
nice sound and rumble
Old 01-18-2011, 03:31 PM   #24
Lol. Thanks. I've got a vid of my new mustang too. The 89. It's on my page.
Old 01-18-2011, 03:35 PM   #25
Well, if you don't like those setups then okay. But yea. Get a tuner for it if you don't already have one. Lower it a little. I had Monroe gas matic shocks on mine. It sat just right. Get a 8.8 rear end with some 3.55s or 3.73s or get a t lok setup. And if needed, get some wheel spacers to make it wider in the back. I'd also tint the windows.
Old 01-19-2011, 06:55 AM   #26
Re: hello
I have Flowmasters, but the 10 Series. Same car as yours. '97 V6-true divorce duals, CAI, ect..
Old 01-19-2011, 07:02 AM   #27
A.K.A. Baby-D!
Re: hello
welcome! car looks great, you can tell it was taken care of properly
Current:
1989 GT--the project
Previous:
2004 V6--my first pony
1988 GT--July 2010 MOTM
Old 01-19-2011, 07:25 AM   #28
Loraco's Avatar
Send a message via Yahoo to Loraco
Welcome!!!!
APRILS MOTM to drive is the reason the destination is just the excuse.
Loraco is offline   Reply With Quote
Old 01-19-2011, 12:07 PM   #29
Re: hello
i like all those systems i was just sayin that mine sounds like that now and i have 1.5 inch wheel spacers on the back and i think lowering it would be a good idea and some 3.73 gears i heard are good, i am getting my windows done in april, it got the fish bowl effect goin on now with no tint lol
Old 01-23-2011, 03:18 PM   #30
Re: hello
Lol. Yea, if it already sounds good, then thats even better. And, cool.
11:33 AM
