95 mustang 3.8L V6 engine knocking - Mustang Evolution
Old 01-15-2011, 12:56 PM   #1
engine has knock at idle until i put 3 lbs. of external vacuum to egr valve. have replaced egr valve and egr regulator. Any recommendations on how to solve this problem? Your help would be greatly appreciated.
Thanks....
95mustang is offline   Reply With Quote
Old 01-15-2011, 07:07 PM   #2
blackonblack's Avatar
Re: 95 mustang 3.8L V6 engine knocking
do you have a cold air intake? if so check to make sure its in there tight, mine wasnt and use to m ake a knock when i was idlle
2004 3.9L v6
Black on black on black
MAC Cold Air Intake, 4.10 gears + T-Lok, SCT Tuner, dual H piped flowmaster super 40's
blackonblack is offline   Reply With Quote
Old 01-16-2011, 02:12 AM   #3
You have got me on this one. Never heard of a knock going away when you open the egr valve. Unless it knocks at idle speed and when you put vacuum to the egr it idles the motor down and thats what causes the motor to stop knocking. I'll try to do some research and figure it out for you.
Straublittleman is offline   Reply With Quote
Old 01-21-2011, 02:20 PM   #4
Re: 95 mustang 3.8L V6 engine knocking - PLEASE HELP
95 3.8L V6 mustang does knock at idle. when applying 3 lbs. vacuum to egr valve it idles the motor down and the knocking stops. We have replaced the egr valve and egr air solenoid. We discovered that the cam sensor was 180 degrees out, corrected that but still continues to knock at idle. We have checked the pistons, lifters, rocker arms, injectors. We have listened with the stethescope and knocking sound can be heard at the intake air box as well as the egr valve which makes it very difficult to pinpoint the exact location of the source of the knocking sound.
Engine Knocking NotoriousSPG Pre-2005 V6 Mustang 10 07-08-2010 04:42 PM
Help me diagnose this knocking Kiljosh Pre-2005 V6 Mustang 7 05-25-2007 10:41 PM
Knocking 3.8 Skip Fix Pre-2005 V6 Mustang 5 03-31-2007 09:26 PM
Engine knocking sound (video inside) Brent Pre-2005 V6 Mustang 19 12-02-2004 11:32 PM
Knocking engine Black Panther Pre-2005 V6 Mustang 25 11-02-2004 06:57 PM
11:41 PM
