supercharger help for my v6 musatng - Mustang Evolution
Old 01-15-2011, 01:03 PM   #1
i just bought a 97 v6 mustang, it has 180xxx klicks so its not to much for the year, i only payed 2500 for it and there isnt 1 thing wrong its in mint shape, it currently has a cold air intake, under drave pulleys, custom leather seats, and billet take offs from a new mustang, true dual exhaust also. i just bought a super charger kit for it, it was used but not very much use, its an eaton and i also picked up one of the volo chips and 30lb injectors, i hear that the 30lb injectors limited the horse power and arnt the best any one have any suggestions on other sizes, i got a boost, volt and air to fuel gauges and the pillar also, i have built alkind of sound systems, my last was 1 15" rockford fosgate in ported box and 3 10" RE audios, it was nuts but weight alot so i just thought id rip all that out and build a new one, i only going to use 3 10"s so ill keep everyone updated but away from all of that, i was just wondering if i will need anything else to put my super charger on and what are some good things i could do to the car aside from all that, just let me know like anything from the motor to the interior to exterior..thanks
chris purcell is offline   Reply With Quote
Old 01-15-2011, 01:11 PM   #2
Camo1967Mustang's Avatar
Re: supercharger help for my v6 musatng
i cant help you on the supercharger
never had one and just know a little about 'em
ur car looks really nice and the interior is beautiful!!
the only things that i see that i would do is smoke the headlights and tail lights (if u can, i know some states don't like that)and maybe some black rims
red and black goes good together
to me that makes it look more aggressive
Camo1967Mustang is offline   Reply With Quote
Old 01-15-2011, 02:28 PM   #3
If you're running the m90, you'll be ok, but if you're running the m112, you might want to go with #39's.
19Delta is offline   Reply With Quote
Old 01-15-2011, 02:38 PM   #4
my head lights are smoked and i am going to get my door panels and the rear quaters wraped in black leather, pretty much everything you see in side thats grey is goin to be black, check my profile tomorrow, i should be done my new soundsystem and a few more things
Old 01-15-2011, 02:41 PM   #5
i have the m90so i guess im good but i hear that the 30lb injectors limit horse power and that i could get somethin better i have no clue i was just ready up on it and i just wanted to make sure i had the best, how many horse do you think ill get out of it
Old 01-15-2011, 03:17 PM   #6
maybe 220? I would def. go with the splitport swap and the m112 if you're looking for a good power adder.
Old 01-15-2011, 03:23 PM   #7
Titus Wadicus
svtlx's Avatar
i think he is sayn that he already purchased the blower
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-15-2011, 04:01 PM   #8
i have already bought it
Old 01-15-2011, 11:03 PM   #9
The m90 is most definitely not the most efficient power maker. 30lb injectors should be just fine as I don't see you making enough power to need bigger. They only limit the power if you're able to make it.
Old 01-16-2011, 09:00 AM   #10
what kind of installation kit did the blower come with?
Old 01-16-2011, 03:02 PM   #11
im not sure, i know everythings there to put it on
Old 01-17-2011, 11:00 AM   #12
Titus Wadicus
svtlx's Avatar
dude i certainly hope so, ppl have a bad habit of selln partial kits when it comes to used units. good luck with your install.
Old 01-17-2011, 12:33 PM   #13
thanks ill put some pictures once i get it put on
04' 3.9 Musatng engine problem video!!! Zebs5408 Pre-2005 V6 Mustang 5 02-04-2010 06:40 AM
2000 musatng gt Hotrod383 General Mustang Discussion 8 12-20-2007 09:28 AM
Supercharger ? Justin 1979-1995 Mustang GT 11 05-12-2006 08:01 PM
Supercharger? 19ClearCobra96 The Bar 16 01-17-2005 10:29 PM
07:05 PM
