exhaust help - Mustang Evolution
Old 01-15-2011, 04:20 PM   #1
exhaust help
hi, i have a 97 v6 mustang and i was wondering if a flowmaster exhaust from a 97 gt fit my car, heres the link
Flowmaster American Thunder Catback Exhaust System (94-97 GT/Cobra) at AmericanMuscle.com - Free Shipping!
i currently have true dual exhaust but its not loud and rumbley like other after market exhaust are
chris purcell is offline   Reply With Quote
Old 01-15-2011, 10:58 PM   #2
Re: exhaust help
It will not bolt-up.
You have two options. Buy the adapter or have an exhaust shop cut your y-pipe after the cats and make new pipes from there to the catback.
Old 01-15-2011, 11:01 PM   #3
Re: exhaust help
If you want a nice rumble at low rpms, look into some aftermarket longtubes with your choice of muffler and have a shop weld it up for you.
19Delta is offline   Reply With Quote
Old 01-17-2011, 07:49 PM   #4
Re: exhaust help
The GT exhaust can go on once you install a legitimate "V6 dual exhaust conversion kit". The GT mid pipes will connect from there and the mufflers and then tail pipe will go right over the axle. Dynomax made the one I used(M#89302). PaceSetter (M#82-2921), STEEDA (M#16065), and L&M (M#P822920)
Put one of any of these on your V6 and you can go with any V8 (94-98) kit you want to. I would just recommend trying to keep it 2.5" or probably 2.25" piping.
Good Luck!
Old 01-17-2011, 08:17 PM   #5
Re: exhaust help
Here are two vids of what I've got done to mine.
Old 01-18-2011, 04:42 AM   #6
Re: exhaust help
thats what mine sounds liek but i want the rumblke when its idleing
Old 01-18-2011, 04:50 AM   #7
Re: exhaust help
Well the only way to get it is longtubes and a chambered muffler.
Old 01-18-2011, 07:38 AM   #8
Qwik Four Six's Avatar
If you want the rumble...I had a 97 catted h pipe 2.5 piping and 2.5 tips and flowmaster super 44s. Go to YouTube and type in 1997 mustang v6 flowmaster super 44. Look for the vid with the username Branman2012
Qwik Four Six is offline   Reply With Quote
Old 01-18-2011, 07:44 AM   #9
Re: exhaust help
as said above buy a dual exhaust adapter then a GT catback should work once you pick up a set of exhaust hangers that you are missing
the issue with just having the Y pipe cut off and true duals welded on is just that... welding them on means they cant easily be unbolted to access the transmission. If you need to get at it you will have to cut the pipe off. They may can weld on flanges and bolt/unbolt the exhaust. They should use stainless steel ONLY in 2.25 inch diam pipe custom bent of course and make sure they clear the axle area high and wide for future lowering plans
some ***** about the gas lines, GT's run their pipes the same way so no issues there as the pipes will be somewhat close to the gas lines.
Old 01-18-2011, 09:48 AM   #10
Re: exhaust help
Just a FYI- EBay has a divorce dual kit exactly what I used for $40.00 that I saw this morning.
Old 01-18-2011, 12:49 PM   #11
Re: exhaust help
mine sounds exactly like your videos you linked there, i want the deep rumble
spectorV: so your sayin i could get this pipe i linked and get the adaptor that you talkin about and itll bolt right on, someone said somethin about long tube headers to, are those worth it and will just that flowmaster give me the rumble and any horse power?
Old 01-18-2011, 01:36 PM   #12
Re: exhaust help
the adapter will have to be cut/welded on. it wont just bolt up. The only bolt up system would be to replace the Y pipe entirly with a high flow cat or offroad pipe that has the dual exhaust bolt up ends for a GT catback.
long tubes wont help you much power wise and are not worth the trouble.
exhaust
Exhaust jaredp Pre-2005 V6 Mustang 7 04-23-2007 11:27 AM
Is there such an exhaust? catskills 1979-1995 Mustang GT 9 10-04-2006 03:32 PM
my exhaust mustang0386 Pre-2005 V6 Mustang 4 09-28-2006 11:07 PM
New Exhaust Help mj5lc 1996-2004 Mustang GT 0 09-09-2006 09:29 AM
03:39 PM
