lookin for a spot to get my engine built up in the future - Mustang Evolution
Old 01-19-2011, 07:06 PM   #1
as some of you know i have a 97 mustang that i just got a supercharger for, i know if i drive it hard it wont last for a long time as it being the stock internals an 180 thousand on it, when i do get it beefed up on the inside i just wanted to know if i should get it cammed at the same time and what should i get done with what parts, i live in halifax nova scotia witch is in canada so i wanted to know if theres anywhere somewhat close or around boston because i got there alot, if you have any suggestions just let me know...i wont get this done until my motor now gets really bad or takes me to the side of the road with parts all over the place lol i just want to know where to get it done
chris purcell is offline   Reply With Quote
Old 01-19-2011, 07:13 PM   #2
Titus Wadicus
svtlx's Avatar
Re: lookin for a spot to get my engine built up in the future
isnt your car a v6? if your gonna stay under 14psi i wouldnt worry bout beefn it up, stock rebuild should be fine. and camn it us an option if you want. but u may wanna upgrade valve springs if u cam it.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-19-2011, 08:24 PM   #3
Super Six Motorsports - V6 products that make your life faster
Go there and check them out. Especially if you want to add some horses to your rebuild.
19Delta is offline   Reply With Quote
Built Engine and some other random parts 95StangV6 Mustang Parts for Sale and Wanted 2 04-09-2007 07:30 AM
How to spot a tard PureVenom Pictures and Videos 19 09-27-2006 12:41 AM
08:43 PM
