Head light casing - Mustang Evolution
Old 01-21-2011, 11:29 AM   #1
Nog51's Avatar
Head light casing
Tried to change my head light bulbs today when i discovered my right headlight will not come out. I hav no idea what cld cause this but i really need to change the bulb. Anyone else had this problem?
Nog51 is offline   Reply With Quote
Old 01-21-2011, 11:36 AM   #2
Re: Head light casing
what year car?
Old 01-21-2011, 11:39 AM   #3
Nog51's Avatar
Originally Posted by SpectorV
what year car?
2002
Old 01-21-2011, 11:43 AM   #4
in order to get the headlight out its actually very easy. Notice the two little clips that you can pull up on. The attached pic has one of them circled in green. There are two per side. Pull those straight up and out.
After that wiggle the headlight and it will pop out and you can unplug the light easier and change it.
I would put a towel down under the headlight to keep it from scratching the paint.
Old 01-21-2011, 11:49 AM   #5
Nog51's Avatar
Yeah i got the left head light out just fine. Toook the pins out and it poped out jus fine. But this one seems like its superglued in there lol. I took the little pins out but it will NOT budge at all. Wut shld i do about tht
Old 01-21-2011, 11:51 AM   #6
I replaced my drivers side the other night and it was stuck in there a bit. There are two metal guides that hold it on by the turn signal.
I would wiggle and tap that area gently and wiggle it up and down then pull out etc, keep at it and it should pop out. You can also push where the pins were at, you can see the part of the headlight the pin goes through, push there with your hands.
Old 01-21-2011, 12:04 PM   #7
Nog51's Avatar
Its still nt wntin to come out, anyother suggestions?
Old 01-21-2011, 12:42 PM   #8
not really other than put a towel under the light and just try to pull as you wiggle it up down/left right... cant think of anything that would hold it in.
Old 01-21-2011, 11:16 PM   #9
Nog51's Avatar
Got it! Aparently the guy tht had it before me tried to seal them and ended up gettin the sealer stuck to the head light and the car. Thx for the help
« I' back!! | Size? »
Head light knob shaft removal jaykay 1979-1995 Mustang GT 4 10-08-2009 02:23 PM
'07 GT head light issue olds350 2005-2010 Mustang GT 2 07-29-2009 11:16 AM
Moisture in the head light. 99 SVT Cobra 1996-2004 Mustang GT 5 07-21-2009 10:19 AM
Sylvania Head Light Bulbs TafoyaMNAA Mustang Parts for Sale and Wanted 0 07-13-2007 12:05 PM
problem with head light look like it crakling tonyd Mustang Audio & Video 8 01-17-2004 11:00 AM
02:45 AM
