Tie Rod - Mustang Evolution
Old 01-23-2011, 03:13 AM   #1
Kamakanani0's Avatar
Tie Rod
So I was told the tie rod is making this squeaking sound and just wondering how much it will cost to replace it thanks
Kamakanani0 is offline   Reply With Quote
Old 01-23-2011, 03:23 AM   #2
Re: Tie Rod
First of all, welcome to the site!
Your best bet would to be to check with your local parts store. What year is your car?
93CobraGuy is offline   Reply With Quote
Old 01-23-2011, 03:27 AM   #3
Hi okay so ask them and they will recommend something? I have a 1995 v6
Old 01-23-2011, 03:29 AM   #4
Re: Tie Rod
Absolutely. Also, when I do tie rod ends, I usually do both sides at the same time. They should be cheap enough that this will be a good idea.
Old 01-23-2011, 03:39 AM   #5
What do u think they will recommend? I'm new to cars and Mustangs. This is my first car
Old 01-23-2011, 03:43 AM   #6
Re: Tie Rod
Is the front squeakng when you turn the wheel side to side?
Old 01-23-2011, 03:45 AM   #7
Yes every turn. I was told that the right side is the one squeaking
Old 01-23-2011, 03:51 AM   #8
Is the tie rod bad or just squeaking? Does it have a grease fitting?
Alscobra is offline   Reply With Quote
Old 01-23-2011, 03:53 AM   #9
Re: Tie Rod
Then that's probably what it is. Like I said, If it were me I would go ahead and replae both sides.
A tip for tie rod ends, before you take your old ones off, mark the threads that they attach to with some white paint. That way when you install your new ones you can screw them on to where the old ones were. I have done this to several, and as far as I could tell, my alignment was still pretty much right on.
Old 01-23-2011, 03:57 AM   #10
Re: Tie Rod
A good way to tell if they are junk or not is to jack the front up and move the wheel with your hands side to side. If there is a lot of movement, they are done for!
Old 01-23-2011, 12:44 PM   #11
Thanks guys how much do the tie rods cost range from
Old 01-23-2011, 04:01 PM   #12
Re: Tie Rod
CJ Pony Parts (site sponsor) has the inners for 15.95 each and outers for 20.95 each.
Old 01-24-2011, 01:00 AM   #13
Wow that's cheap I thought it was alot cool thanks
Old 01-27-2011, 01:14 AM   #14
BIG_K's Avatar
Re: Tie Rod
$18 bucks a piece for outers @ napa... plus an alignment is recommended when you install them..
00' Mustang : totaled
06' Mustang : DD
83' AMC Spirit GT: Weekend Warrior
BIG_K is offline   Reply With Quote
Old 01-28-2011, 04:41 PM   #15
Sweet thanks
Old 01-28-2011, 09:10 PM   #16
Blogger
99ford's Avatar
Re: Tie Rod
^+1. Also while your in there take a look at all your suspension componets to make sure they are all in working order. Odds are the tie rod ends will solve the problem and save your tires. Do you notice a vibration/play in the steering wheel?
and welcome to the site! I think you will enjoy your Mustang, for years to come. That's a great Mustang to start with.
rod length upton7 1996-2004 Mustang GT 2 12-18-2009 11:10 PM
Tie Rods runvsofthisbull Pre-2005 V6 Mustang 20 05-08-2009 02:22 PM
making a battery tie-down? tedness Pre-2005 V6 Mustang 6 10-30-2005 04:22 PM
Tie Rod: Smokedya95stang Pre-2005 V6 Mustang 3 05-10-2004 11:29 PM
We Have A TIE! ---> Postwhore updates Ken The Bar 25 11-27-2003 11:12 PM
09:45 PM
