t3/t4 turbo ? - Mustang Evolution
Old 01-24-2011, 06:02 PM   #1
t3/t4 turbo ?
well guys wanted to see if the this turbo kit was good its on ebay for 500 bks says its complete exept the manifold is it hard to get one made and would that be all ineed or will i have to change injectors and stuff like that or can i run stok for a while with little boost and a good tune
3.8boii is offline   Reply With Quote
Old 01-24-2011, 06:41 PM   #2
Mustangguy0202's Avatar
More air means u need more fuel which means bigger injectors and depending on amount of boost possibly bigger fuel pump gotta keep the air to fuel ratio right and also definitely needs the tune and aftermarket MAF sensor
Mustangguy0202 is offline   Reply With Quote
Old 01-24-2011, 06:52 PM   #3
Re: t3/t4 turbo ?
ok thanks well any recondementions
Old 01-24-2011, 07:28 PM   #4
Titus Wadicus
svtlx's Avatar
Re: t3/t4 turbo ?
u might get lucky and find sum turbo manifolds on ebay. but i would think you would need a minimum of 24lbs inj even at a low 5-6lbs of boost. you could probably get away with stock mass air and fuel pump under 9psi. it would definatley be drivable. but if ur new to the world of boost, u need to stay with 5-6psi till u learn your way around.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-25-2011, 04:35 AM   #5
+1
Old 01-25-2011, 08:39 AM   #6
Re: t3/t4 turbo ?
also remember, you get what you pay for
Old 01-25-2011, 09:01 AM   #7
Re: t3/t4 turbo ?
Yeah, and good luck finding any decent shop who will install a turbo kit on your car from ebay, much less tune your car for it.
sterlingboy is offline   Reply With Quote
Old 01-25-2011, 09:15 AM   #8
Titus Wadicus
svtlx's Avatar
Re: t3/t4 turbo ?
i build my own motors, install my own motors and trans, install and tune my own boost. also, im well aware of the quality of chinese turbos...lol, i think they're wut..$200 bucks. all i would do is get the pipe bent and pay the guy at the dyno. ill do the rest myself.
who am i kidding? im gett'n ready to do my third v6 to v8 efi conversion...who knows when i will get to the chevy?
t3/t4 turbo 3.8boii Pre-2005 V6 Mustang 13 08-27-2010 02:16 AM
Turbo on a V6 ?'s 99'sleeper Pre-2005 V6 Mustang 30 08-31-2005 11:17 AM
Turbo Mjcorn23 Pre-2005 V6 Mustang 12 04-24-2005 11:13 PM
Turbo!!!! steedav6builder Pre-2005 V6 Mustang 16 08-20-2004 11:13 PM
Who wants a turbo! Smokedya95stang The Bar 3 05-13-2004 12:33 PM
04:43 PM
