future plans...? - Mustang Evolution
Old 01-26-2011, 09:34 PM   #1
soccerfreak2143's Avatar
future plans...?
so i have a few plans for my stang. typical ezhaust, gears, cai (gonna put in next week) and tune. if i stick with my v6 through college i want to do a bigger mod on it...my thoughts were nitrous or t3/t4 turbo...not sure which to go with? i hardly know anything about either of them so pros/cons of both would be helpful...
soccerfreak2143 is offline   Reply With Quote
Old 01-26-2011, 09:57 PM   #2
Re: future plans...?
I don't know allot about both either but I myself would want a turbo just because you have to refill the bottle all the time if you use it allot and a turbo is always there.
Straublittleman is offline   Reply With Quote
Old 01-27-2011, 04:24 AM   #3
I wish I could afford a turbo. But my purple bottle is curing my need for hp at the moment
Old 01-27-2011, 04:25 AM   #4
meteorachick's Avatar
check local laws for nitrous, its not legal in all states, other than that, i would turbo that thing
Modified 2004 V6
Old 01-27-2011, 04:34 AM   #5
I am Canadian ....we dont have sniffer laws here and no such thing as an off road exhaust cause we don't even need cats....mind you the population of the province I live in is about a million and we are twice the size of michigan. Clean air and water all around. -40 in the winter and 35c in the summer....and zero smog laws
Old 01-27-2011, 07:06 AM   #6
Chick Nasty's Avatar
Send a message via AIM to Chick Nasty
dont look in my trunk .... dont turn me in ok?
Chick Nasty is offline   Reply With Quote
Old 01-27-2011, 07:15 AM   #7
N2O is just not a good way to go in my opinion... far to much hassle and its usually illegal to use on the street.
Old 01-27-2011, 09:20 AM   #8
I'm with Spec, no nos. Go turbo.
Old 01-27-2011, 10:00 AM   #9
Titus Wadicus
svtlx's Avatar
your tuning window on n2o is fairly narrow and unforgiving. definatley go boost..supercharge or turbo all the way!!!
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Future plans Greywolf Pre-2005 V6 Mustang 5 06-23-2009 08:21 PM
My future plans for the car SpectorV Mustang Audio & Video 22 11-25-2004 07:38 PM
got some plans! whipster24 Pictures and Videos 7 09-22-2004 04:58 PM
Future plans? Tbird232ci The Bar 19 04-25-2004 09:36 PM
07:19 AM
