new engine - Mustang Evolution
Old 02-03-2011, 08:07 PM   #1
DSGstang513's Avatar
new engine
Just replaced the old engine with another 3.9l but running egr delete and long tubes with cai stock internals running real rich and missing a bit could the lack of front and rear o2s cause it to run that rich?
DSGstang513 is offline   Reply With Quote
Old 02-03-2011, 08:50 PM   #2
Titus Wadicus
svtlx's Avatar
Re: new engine
are you running any o2's at all? do you still have the egr still pluged into the sensor?
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-03-2011, 08:51 PM   #3
No egr at all, stock ecu, no o2s not throwing any codes
Old 02-03-2011, 09:22 PM   #4
Titus Wadicus
svtlx's Avatar
Re: new engine
u gotta have sum o2's hooked..im pretty sure at least the upstreams...i think u can turn of the downstreams though if u have an obd2 system. i know if you have obd1, you need to at least have the sensor hooked up, or one of those sensor replacements so it's not in open loop.
Old 02-03-2011, 09:23 PM   #5
ObdII 04
Old 02-03-2011, 09:24 PM   #6
Think that will fix my rich problem idles so hard
Old 02-03-2011, 09:26 PM   #7
Titus Wadicus
svtlx's Avatar
Re: new engine
dude u need to hook up your 02 sensors...extend those wires and hook them up
Old 02-03-2011, 09:27 PM   #8
Will be done first thing tom morning
Old 02-03-2011, 09:33 PM   #9
Titus Wadicus
svtlx's Avatar
Re: new engine
u cant run without 02's...u can disconnect the rear/downstream with a tuner...but u have to have the front/upstreams...good luck
Old 02-03-2011, 09:37 PM   #10
Think it should fix the idle problem and rich problem?
Old 02-03-2011, 09:39 PM   #11
Titus Wadicus
svtlx's Avatar
Re: new engine
most definatley....if you got all the o2's disconnected..for sure
Old 02-04-2011, 01:17 PM   #12
O2s didn't help...any thoughts two collectors are not getting hot on headers
Old 02-04-2011, 07:08 PM   #13
Possibly be crossed plug wires? Or bad coil?
Old 02-04-2011, 10:36 PM   #14
http://www.youtube.com/watch?feature...&v=cMBxOAbpvIM
Video of issue
Old 02-05-2011, 01:00 PM   #15
Re: new engine
anyone got any thoughts? plug wires are good possibly plugs? or coil?
Old 02-05-2011, 03:31 PM   #16
Bump
Old 02-06-2011, 09:17 AM   #17
Titus Wadicus
svtlx's Avatar
Re: new engine
do you mean exhaust tubes? did you have the valve springs or rockers off at any point?
not saying this will help, i saw the video. my car runs like crap and wont idle the last time i tried to tune it with open headers, even with the o2's connected. have you tried bolting up the rest of the exhaust.
Old 02-06-2011, 10:30 AM   #18
Valve springs and rockers never off and two header tubes wont get hot
Old 02-06-2011, 10:38 AM   #19
I swapped plugs and now only one cylinder is fireing and they are gapped correctly
Old 02-06-2011, 10:39 AM   #20
Titus Wadicus
svtlx's Avatar
Re: new engine
idk dude...check your injector plugs... swap a injector wire from a hot cylinger to a cold cylinder and see if it turns on...
Old 02-06-2011, 10:40 AM   #21
Titus Wadicus
svtlx's Avatar
Re: new engine
idk wut u mean one is firing...you mean one came on?
Old 02-06-2011, 10:48 AM   #22
Loraco's Avatar
Send a message via Yahoo to Loraco
Re: new engine
Loraco is offline   Reply With Quote
Old 02-06-2011, 11:04 AM   #23
Vac leak?
Old 02-06-2011, 11:07 AM   #24
Only one cylinder fireing means only 1 out of 6 is moving generating heat
Old 02-06-2011, 11:35 AM   #25
Its keeps jumping cylinders and diff ones get hot its weird
Old 02-06-2011, 01:37 PM   #26
Titus Wadicus
svtlx's Avatar
Re: new engine
im totaly lost..sounds like pcm issue, maybe grounding, im definatley outa my element of expertise without bn there to see it...im sorry.
Old 02-06-2011, 02:42 PM   #27
Pull some plugs. By now they are gonna be fuel soaked or dry. If dry prob fuel issue. If wet or strong fuel smell, fire problem.
Alscobra is offline   Reply With Quote
Old 02-06-2011, 03:37 PM   #28
Plugs are black fuel soaked
Old 02-06-2011, 03:42 PM   #29
Injector is not the prob. No fire. Cam crank sensors maybe. PCM. Wiring.
Old 02-06-2011, 03:54 PM   #30
Cam sensor wouldn't cause that pcm isn't problem, possibly wording but I don't see where it went wrong
Old 02-06-2011, 03:57 PM   #31
replaced some plugs she won't start now
Old 02-06-2011, 03:59 PM   #32
You need a scan tool, wiring diagrams, possibly diag flow charts. Right now you are just guessing.
Old 02-06-2011, 04:14 PM   #33
I got a scan tool no codes. P1000 generic code fro. Sct tuner
Old 02-06-2011, 04:31 PM   #34
Titus Wadicus
svtlx's Avatar
Re: new engine
wut part of ohio r u in? r u anywhere near columbus?
Old 02-06-2011, 04:38 PM   #35
Cicinnati area
V6 Engine Help kack85 Pre-2005 V6 Mustang 3 01-08-2009 09:37 PM
Engine noise from COLD engine 03GreyMach1 1996-2004 Mustang GT 10 03-14-2008 07:40 PM
engine swap 1989 to 1992 4 cyl engine dannyc1992 General Mustang Discussion 0 02-08-2008 01:59 PM
Engine Swap/ Engine Shakes too_cool_mitch Pre-2005 V6 Mustang 2 02-28-2006 02:01 PM
My new engine fast64 The Bar 3 09-09-2003 04:18 PM
04:16 AM
