Turns over but wont start - Mustang Evolution
Old 02-04-2011, 06:21 PM   #1
low2000's Avatar
Region: Oregon
I have a 2000 3.8 that I just tried to change the plug wires on. After about 2 hours, I finally gave up (because I could not get the clip on the back of the motor between the firewall and block open to allow the wires to be replaced) and put it back together. I didn't disconnect anything except the plug wires #1, 2 and 3 from the spark plugs and from the coil pack. After putting it back together I tried to start it. Guess what? Nothing. The motor turns over but usually it fires after about 1 - 2 seconds. I checked the fuel shut off but am stumped at why it won't start now. Does anyone have any ideas. Thanks so much.
low2000 is offline   Reply With Quote
Old 02-04-2011, 06:24 PM   #2
Did you put the plug wires back on the right plugs
Old 02-04-2011, 06:25 PM   #3
Re: Turns over but wont start
Coil wire?
93CobraGuy is offline   Reply With Quote
Old 02-04-2011, 06:46 PM   #4
low2000's Avatar
Region: Oregon
All plug wires are on the correct plugs and matched to the coil pack.
Hey guys, thanks so much for your input. I actually fixed this myself. I unplugged the wire to the coil pack and plugged it back in and it started just perfect. I have no clue why that worked but thought I would try. Again, thanks so much for helping.
Old 02-05-2011, 11:04 AM   #5
stampde's Avatar
YOUR supposed to take the upper intake off on that car when doing plug wires .
That's why your'e having so much trouble with them, its in the way ,,
2011 GT Auto
Old 02-05-2011, 12:17 PM   #6
1.wrong firing order
2. Wrong plugs or wires
3. Bad ignition coil
Pascullon is offline   Reply With Quote
2004 Mustang GT turns over but wont start. Lola 1996-2004 Mustang GT 9 08-31-2010 09:35 PM
Help It Wont Start... kack85 Pre-2005 V6 Mustang 5 07-28-2009 07:14 AM
wont start !!! too fast Pre-2005 V6 Mustang 7 04-24-2009 07:26 AM
wont start???? bluestang1724 1979-1995 Mustang GT 11 01-04-2008 09:10 AM
wont start joezappitella 1979-1995 Mustang GT 5 12-04-2007 08:17 PM
08:12 AM
