Looking for parts. - Mustang Evolution
Old 02-06-2011, 10:25 AM   #1
Looking for parts.
Looking for a FRPP T-Lock for my rear end (2003 V6 Mustang 7.5). Any help will be appreciated.
vnicastro is offline   Reply With Quote
Old 02-06-2011, 10:31 AM   #2
Titus Wadicus
svtlx's Avatar
Re: Looking for parts.
i got mine from jegs..it was like 200 buks i think. you should really try to get that part new if its in your budget.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-07-2011, 06:06 AM   #3
Americanmuscle, stangmods, mossmuscle, cjponyparts, summitracing, brothersperformance, They all have a choice of T-Loks to choose from priced at about $220.00 at the most for 7.5 T5.
Old 02-07-2011, 07:28 AM   #4
I think Ford stopped making them~ not sure though. You can also do an Auburn Diff or what not instead of a Ford brand Tlok (Auburn diff's are stronger as well fyi)
Old 02-07-2011, 12:24 PM   #5
I know they stopped making the frpp gears but you should be able to find the tlok no problem. The detroit or auburn are much better though
tigerfan2771 is offline   Reply With Quote
New parts Ninethourpm Pre-2005 V6 Mustang 21 04-04-2010 08:46 PM
v6 to true exaust. buying parts. am i buying the right parts steveyb927 Pre-2005 V6 Mustang 4 04-16-2009 10:04 PM
Crazy Singe Port Performance Parts/ 94-03 Parts Forged! v6stanger Mustang Parts for Sale and Wanted 4 10-27-2006 12:13 PM
4.2 split port engine parts/torque converter/steeda parts Horse Mustang Parts for Sale and Wanted 33 03-17-2006 04:03 PM
looking for parts project232 Pre-2005 V6 Mustang 31 03-03-2005 06:04 AM
12:17 AM
