02-07-2011, 07:46 AM
#1 | | Registered User
| 3.8 flowmaster?
I'm getting a muffler soon and I have hears stuff about the flowmasters not sounding great on sixers
Any help is appreciated
02-07-2011, 07:50 AM
#2 | | Evolution's Finest
I just had the pipe divorced on mine with two flowmaster 40's put on, and I have the cats still. Sounds like junk. But there are some flow setups I've heard that sound great. Check YouTube and listen to a bunch of different ones and see what you like.
Just because something "can" be done, does not mean it should be done....
02-07-2011, 08:05 AM
#3 | | Terminator Owner
| Re: 3.8 flowmaster?
they sound about as good as anything will sound, they all sound good down low.. but once you get above about 2500 rpms its all down hill from there
__________________ 2003 Cobra Vert (Redfire) #3938 of 5082 @ 05/27/2003
472rwhp/493rwtq - Modification List - Dyno Sheet 2012 Mustang 3.7L M6 (Kona Blue) 2011 Ford Edge Sport (Red Metallic) |
02-07-2011, 10:15 AM
#4 | | Titus Wadicus
| Re: 3.8 flowmaster? Quote:
Originally Posted by SpectorV they sound about as good as anything will sound, they all sound good down low.. but once you get above about 2500 rpms its all down hill from there  | +1
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
02-08-2011, 02:57 PM
#5 | | Registered User
| Re: 3.8 flowmaster?
There are too many variables to interject and effect the sound of the exact same mufflers car to car. 2.25" midpipe or 2.5" midpipe. "H", "X", divorced duals, catback. A cai, intake spacer, udp, a SCT tuner together after a dyno tune works to make a nice sounding v6.
I am using Flowmaster 10 Series mufflers. Not something for any or all v6 Mustangs but sounds out of this world great on my Mustang with my engine modifications.
Go to YouTube. My FM 10 Series are on there along with the 40 Series, 44 Series, and others that work nice like Thrush Welded, MAC, Corsa, Dynomax, Magnaflow, Ford Racing. The 4" Ford Racing mufflers are one of my favorites now.
Keep looking and do a ton of research. Tons of variations. Have fun with it, it was my favorite part of working on the Mustang (after new gears installed).
__________________ '97 3.8L V6 Pacific Green 1996 SVT Cobra White |
