new carpet and console - Mustang Evolution
Old 02-07-2011, 11:44 PM   #1
just bought some new black carpet for my 96 mustang is there a way to paint the vinyl in the car black also that wouldnt look crappy
catless_stang is offline   Reply With Quote
Old 02-07-2011, 11:49 PM   #2
Re: new carpet and console
Painting is all in the prep work done. The vinyl needs to be completely dry and degreased. Isopropyl alcohol works really well for this. Don't skimp when it comes to buying the interior paint either, you get what you pay for. Then it only comes down to the skills you have with a spray can. Hope this helps!
93CobraGuy is offline   Reply With Quote
Old 02-07-2011, 11:55 PM   #3
any specific type of spray brand name?
Old 02-07-2011, 11:58 PM   #4
I prefer Krylon if I buy spray paint. I think they have a specific one just for plastic and vinyl. I have personally never painted an interior, but I have done some amazing to me spray bomb jobs on exteriors. Like I said, good prep equals good paint results!
Old 02-07-2011, 11:59 PM   #5
I think that plastic stuff is called Krylon Fusion. Good stuff from what I have heard.
Old 02-08-2011, 12:08 AM   #6
1ijack's Avatar
Send a message via Yahoo to 1ijack
Well I have heard the same about the Krylon Fusion paint. I spray painted my brake calipers and they seem to come out well. I put three coats on.
The Mustang Mafia
"Join the family, if you dare"
www.themustangmafia.com
1ijack is offline   Reply With Quote
Old 02-08-2011, 12:21 AM   #7
read up on it a bit about the spraying says use 5 coats and let it dry bout 30 min apart each coat thxs for the help
Old 02-08-2011, 12:23 AM   #8
No problem! Hope it goes well for you, good luck!
Old 02-08-2011, 12:30 AM   #9
1ijack's Avatar
Yes it does say to use multiple times. It does give you a nice coat. Just BEWARE OF RUNS! they can kill you. 6 inches apart and nice easy strokes. Take your time and it will turn out great don't rush it.
The Mustang Mafia
Old 02-08-2011, 07:18 AM   #10
they make dye spray paint you can buy and it works VERY good (if done correctly)
Old 02-08-2011, 08:31 AM   #11
Yes, make sure it is "Dye Paint"- Interior dye paint. It has all the adhesion primers ect. inside and ready to go.
Old 02-08-2011, 10:56 AM   #12
Titus Wadicus
svtlx's Avatar
ive done 2 interiors in black. making sure it is completly clean cant be stressed enough, as stated by 93cobra. i think i used amonia and water. i did the carpet (was blue or gray) and the seats. i used extra concentrated rit dye on the seats and the carpet. (carpet looked new when done..wow).
the plastic....the more coats you apply, the shinier it will be..regardless if your using a flat black. if you are into the "freshly armor all'd" look...then definatley apply 6 coats. if you prefer a less shinier (flatter appearance) then you may wanna only do 2 coats.
the seats...everyone i know that's done a dye/paint job, including myself. the seats look nice and black when still wet. but after they completly dry a few hrs or the next day... they turn into this real dark grey charcoal color. ive used the rit dye...still dark grey. ive used the fabric dye in the spray can...within 24-48hrs..dark grey. for whatever reason the dye doesnt take well to the seats. i thought i was doing something wrong till i saw it on other ppl's cars. maybe there's a product i didnt use or a process i didnt do correctly.
everything turned out super black as intended except for the seats. however, the "real dark charcoal grey/black" doesnt look horrible on an all black interior. i found that the only ppl that knew it wasnt factory was other ppl that had dyed theirs too..lol.
i hope this helps...
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Carpet Install StangPride Mustang Audio & Video 8 03-01-2009 08:22 PM
Road calcium on the carpet TNT Bomb Mustang Audio & Video 6 04-13-2005 12:03 AM
Carpet? Tbird232ci The Bar 25 05-14-2004 12:25 PM
Trunk carpet WTB BKB Mustang Parts for Sale and Wanted 1 02-10-2004 09:35 PM
Matching Carpet for rear speaker cover Brent Mustang Audio & Video 5 01-14-2004 11:17 AM
10:19 PM
