3.8 Running Rich - Mustang Evolution
Old 02-09-2011, 10:45 AM   #1
Unhappy 3.8 Running Rich
Hi All,
I have a 98 mustang convertible. I just replaced the computer and the fuel pump. The car is still running rich. Checked the fuel pressure, 70 at the pump, 41 at the rail.
When I start it, the smoke is really thick and will foul the plugs in a few minutes.
Any ideas? I am desperate.
mu_stang is offline   Reply With Quote
Old 02-09-2011, 12:49 PM   #2
stampde's Avatar
Re: 3.8 Running Rich
Mass air meter or maybe the coolant temp sensor
2011 GT Auto
Old 02-09-2011, 12:59 PM   #3
Thanks. I tried the temp but will have the garage look at the mass air meter.
Called the garage, any ideas on how to test the mass air meter?
Old 02-10-2011, 03:25 AM   #4
If you have a CAI "cold air intake" it will be much easier. But if you don't then you need to pull apart your breather and look at the mass air meter. There should be 4 wires if there is more don't panic just look closely at the sensor and there should be letters like SIG, GND, REF, BATT, or something like that. If it does have only 4 wires then the wires you need to test are the middle two (SIG and GND) you will need a digital volt meter set at 20 volts DC or so.
With the car running at idle probe the two wires and see the voltage reading. It should be anywhere between 0.2--1.5 volts at idle. Then rev the motor to see if the voltage rises slightly "at 60MPH it should read 2.0 volts but this is at load conditions" Also you can disconnect the MAF harness connector and use an ohmmeter and probe the terminals SIG and GND. If the element inside the sensor has been damaged it will be indicated by an open circuit (infinite resistance)
Thats how you test a Mass Air Sensor.
Straublittleman is offline   Reply With Quote
Old 02-10-2011, 04:43 AM   #5
Thanks. I am running out of ideas. I do have a cold air intake.
87 Mustang has very high idle and running VERY rich. Any ideas? clannan1 1979-1995 Mustang GT 5 08-21-2010 11:25 AM
I'm RICH!!!! I'm RICH!!!! PureVenom 1996-2004 Mustang GT 34 04-23-2009 09:23 AM
Another 18 year old gets rich off the Net Brent The Bar 4 11-13-2006 11:31 PM
Do u have rich parents MusclesFromBrussels The Bar 28 10-23-2003 08:07 PM
04:21 AM
